Connecting CPVC To Toilet Or Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-30-2012, 06:44 PM   #1
Rewards Points: 50
Connecting CPVC to toilet or sink
does it matter?
What does the second do that makes it better, if it is?
digitalplumber is offline   Reply With Quote
Old 10-30-2012, 07:40 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
Choose the first one.
Do not conceal a fitting that relies on a rubber washer to seal it. The gasket will fail just like they do in a garden hose
Old 10-31-2012, 09:17 AM   #3
Rewards Points: 3,130
Why would the gasket fail? A garden hose gasket fails because hoses are connected and disconnected multiple times. A water line to a toilet never gets disconnected. I've never had one fail in 40 years of owning houses.
Old 10-31-2012, 10:10 AM   #4
Plumber
Rewards Points: 452
IMO-There is no reason to use a gasket connection when you can simply glue CPVC. To take it a step furthur, I wouldn't even use CPVC
I have seen multiple dialectic unions and flex connectors on water heaters that leak at the gasket- they never get disconnected either. Why trust a strip of rubber over a solvent weld joint?
Old 10-31-2012, 02:14 PM   #5
I have never seen a direct solvent-welded connection to a toilet. And every toilet tank I've ever seen has had a threaded male water inlet. So there's going to be at least one gasket no matter what.
Old 10-31-2012, 02:46 PM   #6
Rewards Points: 50
Why not?
digitalplumber is just a name for use here, I am not a plumber!
Old 10-31-2012, 03:06 PM   #7
Plumber
Rewards Points: 452
I assumed the OP wanted to conceal the fitting inside a wall for a sink or toilet stub out- again, I would not. To take it a step further- I doubt my inspector would let me
Originally Posted by digitalplumber View Post
Why not?
why not what, use CPVC? Nobody in my area uses it. Plumbers here tried it and we had too many problems with joints failing for various reasons so we moved on to other pipe products- other choices we prefer are pex and copper.
Old 10-31-2012, 03:16 PM   #8
Rewards Points: 50
Thanks, but from what I have read, the reason you sight to not use it, also occurs in pex and copper, right? I'm in Houston Texas.
Old 10-31-2012, 03:29 PM   #9
Plumber
Rewards Points: 452
I haven't used CPVC in several years and I know the product has improved. But we had problems with fittings failing well into our warranty period- happened more then once and to more then one contractor. So you can see why I'm gun shy. It could have been installer error or product issues. If your area uses it a lot then I'd suggest you stay with it.
Old 10-31-2012, 03:54 PM   #10
Rewards Points: 50
So if I understand you correctly, your decision not to use cpvc is solely based on the joints, correct?
Old 10-31-2012, 04:05 PM   #11
Plumber
Rewards Points: 452
I just found this file. I skimmed over it and I think it addresses my concerns with CPVC. Bear in mind that I was first exposed to the product 10 yrs-or so ago. I'm sure it has improved or it wouldn't be in production today. However, whats the saying? -- once bitten, twice shy......
http://www.cpcplastics.com/pvc_plast...rt_package.pdf
The Following User Says Thank You to TheEplumber For This Useful Post:
digitalplumber (10-31-2012)
Old 10-31-2012, 04:24 PM   #12
Home Remodeler
Rewards Points: 164
Used CPVC when I added a new bathroom, 15 years ago. Not one problem so far.
mikey48 is offline   Reply With Quote
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 11:53 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
toilet, shower valve, pedestal sink, med. cab. Yoyizit Plumbing 0 03-17-2009 01:48 PM
Toilet vent in upstairs sink line DavidT Plumbing 1 02-28-2009 08:29 AM
Caulking around kitchen sink deeaa Remodeling 8 07-13-2008 04:12 PM
