Connecting Condensate Line To Soil Stack - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-21-2017, 12:14 AM   #1
Rewards Points: 214
Connecting Condensate Line to Soil Stack
Ok,
I have included the picture below.
Pretty much what I want to do is connect that 1" condensate line to the 4" stack. This is in the basement and does not vent out to the roof, it simply connects to the entire house and it's the last point before it enters into the concrete slab and into the septic.
My thinking is I should simply be able to cut into the bottom portion of that pipe and put a WYE in there, then put a heavy duty trap in there. I want to "air-gap" it some way so that the condensate line is not sealed with the pipe. I guess my question is if this is against plumbing code? Is it possible that I could screw something into the cleanout plug?
steppinthrax is offline   Reply With Quote
Old 04-21-2017, 09:47 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 820
Re: Connecting Condensate Line to Soil Stack
A proper way to do this to put a condensate pump on the floor. Then pipe the waste to a sink or clothes washer box.
To use the stack would mean cutting in a tee, adding a vent and a trap. Also an air gap assembly.
I take it there are no plumbing fixtures in the basement?
Old 04-21-2017, 12:12 PM   #3
Rewards Points: 214
Ok thanks, I understood the idea of a pump. But why would an vent be needing for a simple trap. There are two rough in plumbing drains in the basement floor. One underneath the toilet in the basement bathroom and one at a nearby utility sink.
Sent from my SM-J700P using Tapatalk
Old 04-21-2017, 12:41 PM   #4
Plumber
Rewards Points: 820
A trap without a vent has the possibility of blowing out from air pressure in the stack as upstairs fixtures drain.
Using the trap idea you propose- You can connect to toilet vent on that floor. Or drain it into the utility sink
Old 04-21-2017, 04:38 PM   #5
Rewards Points: 2,040
You have no sump pit to run it to? If you do run to it.
Ghostmaker is online now   Reply With Quote
Old 04-21-2017, 05:11 PM   #6
Rewards Points: 1,480
Correct me if I'm wrong, but a trap without a vent can also get siphoned dry.
mikegp is offline   Reply With Quote
Condensate Drain Line & Pan Problems hobbzilla HVAC 10 08-04-2014 11:31 AM
How to repair a ABS soil stack with a drywall screw in it? ThatGuy Plumbing 10 02-22-2012 10:36 AM
Condensate line clogged? kcrossley2 HVAC 6 07-27-2011 10:51 AM
soil stack help please treerat Plumbing 3 03-27-2011 08:07 AM
Condensate Line schott HVAC 17 06-02-2008 03:16 PM
