Connecting Clawfoot Tub To Existing Drain Line In Concrete Basement - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-02-2012, 04:48 PM   #1
connecting clawfoot tub to existing drain line in concrete basement
We are trying to replace the shower in my basement bathroom with a clawfoot tub. So far, I have removed the old shower and drain. I will be having a plumber come to reroute and connect supply lines for the tub and also to connect the drain.
The bathroom is in the basement. It has a concrete floor. Coming out of the floor is a 2" cast-iron pipe (which the shower drain was previously attached to). It extends 1" above the floor and is unthreaded. I have measured and this drain should not need to be moved to accommodate the tub.
My question is: Should my plumber be able to connect the tub drain to this pipe (using some appropriate adaptor)? Or, am I going to have to jackhammer out concrete to expose the rest of this pipe and the p-trap it presumably connects to?
Thanks for your help.
michaelflinn is offline   Reply With Quote
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Connecting new 1 1/4 inch PVC trap to old 1/1/2 inch metal drain line dfg13gibson Plumbing 2 08-21-2011 05:16 PM
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 11:54 AM
Cutting Concrete for drain line Piney Building & Construction 2 12-01-2006 07:42 PM
