Connecting ABS To PVC Drain Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-16-2014, 12:41 PM   #16
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 432
Originally Posted by Eagle One View Post
So they are both 1 1/2" but the tubing is 1 1/2" from outside wall to outside wall and the pipe is 1 1/2" from inside wall to inside wall. Right? And I assume it is done this way so 1 1/2" tubing can fit inside 1 1/2" pipe without someone like me wondering how to match up pipes that LOOK like different sizes...haha
Not for necessarily for sliding od into id. Plumbers just like bigger pipes.
BTW, 1-1/2" pipe inside is nominal, not the actual size.
Tubing OD is actual size.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
Old 01-16-2014, 09:17 PM   #17
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Kind of depends on the brand of tubular pvc that you get. Sometimes it will fit sloppily inside of 1-1/2" ABS and sometimes it will be very tight.
The adapter and the compression nut are what make the seal, and some brands of adapters have a stop inside so that the tubular won't slide past it into the ABS. It really just depends on what you get.
Journeyman Plumber
Old 01-16-2014, 09:41 PM   #18
Plumber
TheEplumber's Avatar
Rewards Points: 352
And don't slide it in so far that you block off the 90 or the tee.......
Old 01-16-2014, 10:38 PM   #19
Doing it myself
Alan's Avatar
That's what my hammer is for.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
TheEplumber (01-16-2014)
Basement Sink Rough-in Drain Pipe 325_man Plumbing 5 05-02-2013 08:39 AM
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 11:53 PM
Replace brass drain in lead pipe hercules2424 Plumbing 2 08-09-2011 01:28 AM
connecting PVC drain to a copper pipe? red86yota Plumbing 4 02-24-2009 10:43 PM
New bathroom drain pipe leaks PAK Plumbing 2 07-29-2008 10:36 AM
