Connecting ABS To PVC Drain Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-03-2014, 09:19 AM   #1
Rewards Points: 302
Connecting ABS to PVC drain pipe
I am trying to install a new laundry tub but the existing drain pipe needs to be extending out a few more inches in order to fit the new drain opening in the sink basin. The existing pipe is ABS and the tub came with PVC drain tubing. What is the best way to connect these? I have attached a couple pics to show what I am trying to accomplish. I would like to cut the ABS pipe right around the point where I have the end of the PVC pipe in the second pic.
Connecting ABS to PVC drain pipe-abs-drain-pipe.jpg   Connecting ABS to PVC drain pipe-abs-drain-pipe-3.jpg
Eagle One is offline   Reply With Quote
Old 01-03-2014, 09:36 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,238
Glue and ABS threaded fitting on and use a compression threaded joint.
The Following 2 Users Say Thank You to Windows on Wash For This Useful Post:
plummen (01-16-2014), TheEplumber (01-03-2014)
Old 01-03-2014, 11:55 AM   #3
Civil Engineer
Rewards Points: 4,702
Fernco makes an entire line of couplings that connect two pipes of different material together, no glue, no threads, just a simple rubber boot and a pair of hose clamps. I have used them successfully connecting copper to PVC, galvanized to PVC, and PVC to PVC. The only dimension that is important is the outside dimension of the two pipes, it is best to measure the OD with a caliper prior to purchasing the coupling. You can get Fernco or equivalent at a big box store, or a plumbing supply house.
Daniel Holzman is online now   Reply With Quote
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Gymschu (01-03-2014)
Old 01-03-2014, 12:00 PM   #4
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 972
http://www.homedepot.com/p/Oatey-4-o...003/100344275#
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
Old 01-03-2014, 02:22 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 566
Windows had it right-
Cut between the trap and 90. Then glue on an 1.5" female trap adapter to receive the PVC tube trap. Done deal
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 01-03-2014, 03:25 PM   #6
Rewards Points: 1,870
http://www.grainger.com/product/1WJN...140103212445:s
Get this
Old 01-03-2014, 05:54 PM   #7
Rewards Points: 582
yep cut between 90 and trap...glue in a 1 1/2 desanko fitting this will allow you to connect the new pvc trap to your abs pipe.. ben sr
Old 01-06-2014, 08:39 AM   #8
Rewards Points: 302
Lots of good responses here. Thanks to everyone. With the ABS pipe being 1 1/2" and the PVC pipe being 1 1/4", I don't think I can use the Fernco couplings (assuming the pipes have to be the same size) unless there is another way to do that. I did find that ABS to PVC cement at Home Depot (the 'other' big box store didn't have it!).
I do have another question on this however. I started wondering if there was a way I could use 1 1/2" pipe for the entire drain rather than using the 1 1/4" drain pipe that came with the laundry sink. Obviously, the large drain pipe would be beneficial for faster draining of the washing machine water or anything else going in that sink but I don't think I can do this with the existing drain strainer that came with the sink basin. I assume that I need to use the size they provided (1 1/4") unless maybe I buy a different sized strainer? That might not correctly fit the pre-existing hole though...
I don't want to make this too difficult but would like to do it the right way the first time and if making the drain pipe larger can work, I would be interested in doing that. Is it worth the trouble or should I just stick with that they gave me?
Old 01-06-2014, 08:55 AM   #9
Plumber
Rewards Points: 566
I'm surprised its 1 1/4" as sinks require 1 1/2"
They do make 1 1/2 x 1 1/4 beveled reducing washers for the fitting I referenced.
1 1/2" is standard stub out these days. I always use 1 1/2" traps too.
Also, I would not use the transition glue- seen it fail and there are more preferred ways listed above.
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (01-06-2014), plummen (01-16-2014)
Old 01-15-2014, 03:10 PM   #10
Rewards Points: 302
Upon further review, the PVC P-Trap parts that came with the laundry tub ARE in fact 1 1/2 inch (according to the small stamp on the side). When I measured their circumference, I got 4 3/4 inch with 5 1/8 inch at the J bend collar. So, based on the 5 1/8" measurment, I thought they were 1 1/4 inch pipe. They also LOOK smaller than the black ABS in the picture. The circumference measurement on that is 6 inches so that would appear to be 1 1/2 inch pipe as well. This is me right now......can anyone please set me straight on this?!
Old 01-15-2014, 03:57 PM   #11
Plumber
Rewards Points: 566
1 1/2" drain pipe has larger OD than 11/2" tubing. The white PVC trap is 11/2" tubing
Alan (01-15-2014)
Old 01-15-2014, 04:10 PM   #12
Doing it myself
Alan's Avatar
Rewards Points: 2,086
We refer to it as tubular pvc. Totally. ;-)
Journeyman Plumber
Alan is online now   Reply With Quote
The Following User Says Thank You to Alan For This Useful Post:
ben's plumbing (01-15-2014)
Old 01-15-2014, 05:56 PM   #13
Civil Engineer
Fernco (and others) make connectors that are designed for different pipe sizes on either end. You need to go into a real plumbing store to find them, but they are certainly available. The difference in pipe outside diameter can be due to different material (i.e. iron versus copper) or different size pipe. The best way to measure the diameter of a pipe is with a dial caliper, you can get a plastic one at a big box store for under $5, very useful. The circumference technique is prone to error.
Old 01-15-2014, 06:24 PM   #14
Plumber
Rewards Points: 566
All you need is this and a can of glue-
http://www.homedepot.com/p/NIBCO-1-1...0#.UtcmRNJDtQA
Old 01-16-2014, 09:54 AM   #15
Rewards Points: 302
So they are both 1 1/2" but the tubing is 1 1/2" from outside wall to outside wall and the pipe is 1 1/2" from inside wall to inside wall. Right? And I assume it is done this way so 1 1/2" tubing can fit inside 1 1/2" pipe without someone like me wondering how to match up pipes that LOOK like different sizes...haha
Basement Sink Rough-in Drain Pipe 325_man Plumbing 5 05-02-2013 07:39 AM
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
Replace brass drain in lead pipe hercules2424 Plumbing 2 08-09-2011 12:28 AM
connecting PVC drain to a copper pipe? red86yota Plumbing 4 02-24-2009 09:43 PM
New bathroom drain pipe leaks PAK Plumbing 2 07-29-2008 09:36 AM
