Connecting 2 Dishwashers To Kitchen Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-12-2010, 05:13 PM   #1
Connecting 2 dishwashers to kitchen drain
Do they make a fitting to connect (2) dishwashers to the kitchen drain? Or is there an easy way to fabricate this?
General is offline   Reply With Quote
Old 12-12-2010, 05:55 PM   #2
https://www.fisherpaykelparts.net/pr...l-Air-Gap-Kit/
the_man is offline   Reply With Quote
Old 12-12-2010, 06:26 PM   #3
Originally Posted by the_man View Post
Thanks for the link. Two questions: Is there a way to do it without having to drill thru my granite counter top to install an airgap like that one? Second, is that type of fitting guaranteed not to "cross drain"? It says so on the image, but it looks like one drain would flow right into the other one.
Old 12-12-2010, 06:54 PM   #4
there is a hose for a drawer dishwasher that is 2 hoses coming into 1 end, but i can't remember who the heck makes it. i'll keep looking... or you can just install 2 tailpieces stacked on top of one another and use 2 separate hoses. I've seen 2 hooked up with a homemade tee made out of 3/4 copper, but i wouldn't trust it
Old 12-12-2010, 06:55 PM   #5
I don't think I have the height for two tailpieces stacked on top of each other like you suggested I'm surprised that they don't make one with two inlets, such a simple thing.
Old 12-12-2010, 07:02 PM   #6
not all that common to have 2... dish drawers are changing it, but these things take time i know its out there, i'll keep looking as i have time. maybe dig around on appliance sites, or ask in the appliances section here
Old 12-12-2010, 07:09 PM   #7
I appreciate the help
Old 12-12-2010, 10:29 PM   #8
I just thought of something, those tailpieces with the dishwasher inlet that you mentioned stacking on top of each other, they are usually long so that's why I said that I won't be able to stack two of them. But what if I cut the length off of them and then tie them together with a no-hub? That would give me two inlets without too much height. The only issue is making sure that the water from the top inlet never enters the bottom inlet. I guess that's not really an issue since the water from the sink never gets into the inlet.
Old 12-12-2010, 10:33 PM   #9
Do you have a garbage disposal? Could you put one tailpiece on each basket strainer? If you have a double bowl kitchen sink?
broox is offline   Reply With Quote
Old 12-12-2010, 10:57 PM   #10
No disposal and a normal single bowl sink
Old 12-12-2010, 11:11 PM   #11
They make a DW tailpiece that attaches directly to the basket strainer, then they make a "slip joint" DW tailpiece that could be right under the direct connect one. If there is 6-7 inches between your basket strainer and the top of your trap, I think it would be worth a look!
kitchen sink drain hole lucylu092910 Plumbing 1 04-19-2010 08:59 AM
Connecting PVC to Galv Pipe fitting for Drain froddan Plumbing 19 02-28-2010 03:33 PM
Kitchen Sink Drain Problem Spark General DIY Discussions 9 06-14-2009 11:00 PM
Sudden SUPER slow drain in kitchen through disposal pcampbell Plumbing 11 11-07-2008 05:13 AM
Kitchen Sink Drain - brown buildup? Krista Plumbing 5 09-21-2008 05:27 PM
