Connect To Sewer Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-30-2012, 07:07 PM   #1
Question
Connect to Sewer Line
I'm trying to install a bathroom in my basement however I ran into a snag trying to connect to the sewer line. Under the slab it's all 3'' elbows and a wye with 1.5. Any suggestions on how to connect into this? Thanks.
fanucci is offline   Reply With Quote
Old 04-30-2012, 07:57 PM   #2
Rewards Points: 6,652
Can you post a picture farther back, showing where the 2" goes, and where it goes upward.
The Following User Says Thank You to gregzoll For This Useful Post:
plummen (05-01-2012)
Old 04-30-2012, 08:01 PM   #3
MarginallyQualified
Rewards Points: 2,464
You're going to have to dig farther back to the pipe that exits the house. Then,
1) attach your new fittings (as needed) to that pipe
2) accommodate the existing drain needs as well when you do that work.
hth
The Following User Says Thank You to TarheelTerp For This Useful Post:
Old 04-30-2012, 08:18 PM   #4
gregzoll, here is another picture. Thanks.
tarheelterp, thanks for your reply.
Old 04-30-2012, 08:22 PM   #5
No I am curious even more. Who in the H*** plumbed that mess. How many times have you had the line clogged, or slow down, due to that S curve.
Now, I want to see where that mess goes upwards. Can you post more pic's, due to appears that it needs to be torn out and redone properly, from the little I have seen at this point.
Old 04-30-2012, 08:31 PM   #6
Amazingly enough it has not been a source of problems.
Old 04-30-2012, 08:37 PM   #7
MarginallyQualified
what greg is saying is that it should look more like this:
(ignore that 2" at a cockeyed angle)
Old 04-30-2012, 08:41 PM   #8
Rewards Points: 582
dig further back and redue the plumbing so you can get rid of that mess...don't worry so much about the 2" it will be fine its the 3" that needs the most attention....ben...
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
gregzoll (04-30-2012), plummen (05-01-2012)
Old 04-30-2012, 08:57 PM   #9
Thumbs up
Thanks guys! I got some digging to do!
Old 04-30-2012, 09:06 PM   #10
Also, make sure that you slope that 2" up on top, since it appears to just be straight horizontal. Depending on if you had to take a permit out to do the work, you may have to update it, due to the new "fun" in fixing someone else's mistake.
But, look at it this way. At least they did not use a bunch of couplings and miss-matched chopped off pieces, etc. when they did it originally.
ben's plumbing (05-01-2012)
Old 05-01-2012, 07:10 AM   #11
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
What were they smoking when they laid that mess out?
Since its all exposed Id redo the groundwork so you can bring your other plumbing straight down the wall and cut in an extra wye to bring the basement plumbing into.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
Old 05-02-2012, 09:42 PM   #12
Master Plumber
Javiles's Avatar
Rewards Points: 996
Come on guys do you know a do do roller coaster when you see one.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Tags
basement , connect , sewer
Sewer Line Issues kirksullivan54 Plumbing 2 10-27-2011 03:19 PM
Sewer line material help detroit_fan Plumbing 6 05-09-2011 11:12 AM
cement truck over sewer line SAS Plumbing 20 03-24-2009 09:07 PM
sewer line back fall oakie14 Plumbing 2 09-04-2008 05:36 PM
Adding a phone line to an older connect point cramsmith General DIY Discussions 3 11-23-2005 11:35 AM
