Old 01-31-2010, 06:19 PM   #1
connect sewer to city sewer
I plan to build a new house, I will be my general contractor. one thing, i am not sure. i divide project in several stage: excavate, concrete, fill earth back, framing, ...... I know between concrete and fill earth back, we need connect sewer pipe to city sewer, and ask related company to bring water pipe and gas pipe , power to meter position. is that right? pleas help me.
yuzhenli is offline   Reply With Quote
Old 01-31-2010, 08:10 PM   #2
Civil Engineer
I assume you are in Edmonton, Alberta. You need to check with the local code enforcement official, since you are presumably getting a permit. The code official will almost certainly give you the names of the local utility companies, who will be happy to give you explicit directions as to how to hook up to their services, or else they will do the connection for you (at your expense of course). These are local issues, so unless someone on this forum lives very near you, you simply cannot get explicit answers here.
Sewer Pump: How to make do? austinbirdman Plumbing 2 05-04-2011 10:35 PM
First Question: Water and Sewer Supply sgo70 Plumbing 2 06-16-2009 10:10 AM
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 08:09 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
Sewer pipe under concrete driveway marejw Plumbing 7 12-22-2007 05:19 PM
