Connect Garden Hose To Water Heater Cold Water Inlet? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-19-2010, 01:42 PM   #1
Connect Garden Hose to Water Heater Cold Water Inlet?
I live in an apartment where the nearest water spigot outside is more than 100' away. Consequently, I would like to connect my garden hose to the cold water pipe of my hot water heater which is in my storage closet so I can water my plants. What is the best way to do this? I have not been able to find a copper T with two male and one female connectors. Also, people have told me to connect my hose to an indoor faucet, but I want the hose to stay outside. Thanks!
Geremia is offline   Reply With Quote
Old 11-19-2010, 02:43 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,038
Ayuh,... My guess is, you should speak to the landlord before altering the plumbing...
There are many ways to adapt what you what,...
Even a sales clerk in a plumbing shop could fix ya up...
Old 11-19-2010, 05:15 PM   #3
They maintenance guys I asked did not seem to mind.
Yes, I think I will have to check out a dedicated plumbing store; I've already checked out, to no avail, Home Depot and Ace. I just wasn't sure if there was a sort of generic solution or something I overlooked at Home Depot or Ace. Thanks, though
Old 11-19-2010, 06:40 PM   #4
Bondo's Avatar
What is the waterline you're gonna cut made of,..?? Copper,..??
what size,..?? sweat-fit connections,..??
If so, along with a "T", 'n a hose thread adapter, you'll need a valve,...
I like ball-valves..
Cut the line, install the T, nipple off it to the valve, then to the adapter...
You're Done...
Old 11-19-2010, 07:43 PM   #5
[quote=Bondo;537122]What is the waterline you're gonna cut made of,..??[/quotes]It's a 3/4" copper flex pipe.
Copper,..??
Cut the line
No, I wouldn't want to cut anything.
You're Done...
So basically a ball-valve, a T, and an adapter for connecting to the nipple... yes it sounds so simpleóand I was looking for this at Aceóbut I seriously have to go to a better store...
Old 11-19-2010, 08:23 PM   #6
unfortunatly you will have to cut the pipes. if your piping is copper the best solution with minimal work and problems would be to go to home depot, lowes or local plumbing supply house and ask for a tee, coupling, female adapter all in shark bite. also a boiler drain and the smallest amount of copper you can get. shark bite fittings require no work but to push it onto a pipe and it snaps together. there is no soldering involved.
wellcraft is offline   Reply With Quote
Old 11-19-2010, 08:43 PM   #7
Even though the copper flex pipe manually screws onto the nipple's threading? Couldn't it just screw into the right T adapter?
No, I don't need that because the copper flex pipe can screw into something. The solution is pretty simple, but for some reason I can't find the parts.
Old 11-19-2010, 08:43 PM   #8
No, I don't need that because the copper flex pipe can screw into something. The solution should be pretty simple, but for some reason I can't find the parts.
Old 11-19-2010, 08:50 PM   #9
Plumber
TheEplumber's Avatar
Rewards Points: 562
You said the maintenance guys didn't mind so offer them a couple 6 packs to do it for you. Now they are resposible for any possible problems that could come up
The Following User Says Thank You to TheEplumber For This Useful Post:
oh'mike (11-20-2010)
Tags
connectors , garden , gardening , hose , water heater
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 10:33 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
Cold water hose - washing machine cmcgowan Plumbing 1 01-08-2009 10:13 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
Installing a Tankless Water Heater infoiam Plumbing 4 11-10-2008 09:59 PM
