Connect Chrome P-Trap To PVC Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-15-2011, 11:53 AM   #1
Connect Chrome P-Trap to PVC Drain
My wife and I redid our powder room and are finished with exception of putting in our sink drain. We converted to a pedestal sink and would like to install a chrome drain similar to this Kohler model:
KOHLER K-9000-CP Adjustable P-trap with Tubing Outlet, 1-1/2" x 1-1/2" in Chrome
http://www.us.kohler.com/onlinecatal...02&retail=true
We have a regular PVC drain with a 1 1/2" ID, but it's just cut off clean at this time. I understand that the chrome tube gets inserted into the drain, but I don't know the best way to ensure a seal between the tube and the PVC drain. Do we need to glue a connector to the PVC or is there anything such as a compression fitting, etc. that can be used?
Thanks for the help!
simonua is offline   Reply With Quote
Old 09-15-2011, 12:34 PM   #2
Rewards Points: 150
http://www.homedepot.com/buy/plumbin...er-181576.html
josall is offline   Reply With Quote
Old 09-15-2011, 01:01 PM   #3
Thank you, josall. It looks like all I need to do then is dry-fitting, then priming and cementing the adapter. I appreciate you.
Old 09-15-2011, 01:29 PM   #4
Rewards Points: 150
That's it!
washing machine drain trap question graysqwrl Plumbing 3 09-11-2011 02:26 PM
Adding drain line in basement floor - size and trap? theedudenator Plumbing 0 07-11-2011 09:22 PM
Vent directly between trap and drain, or not? wvphysics Plumbing 17 07-18-2010 04:37 PM
No drain trap in a 7-year old home - is this normal? curls00 Plumbing 2 12-05-2009 12:40 PM
condensation drain trap neliovrod HVAC 1 10-26-2009 05:07 AM
