Confusing Stoppage??? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-24-2013, 08:50 AM   #1
Unhappy
I have a drain in my laundry room next to hot water heater and ac unit. Water is backing up there. Only from my kitchen sink now. I used a main line chemical cleaner in the drain thats filling up. Also in bathtub. NO backing up anywhere in home. Now my kitchen sink is draining but this floor drain backs up when I use kitchen sink??? I have no main line clean out. Home was built in 1962. ANY IDEAS would be great!!! Thank you
rideracewin is offline   Reply With Quote
Old 02-24-2013, 09:15 AM   #2
Rewards Points: 13,456
First thing is never use a drain cleaner. No anyone having to try and snake this is going to have to deal with a toxic chemical.
Some place in those lines your going to see a plug in a tee that's you clean out.
What type pipes do you have.
Where have you tryed to snake it?
Did you remove the trap and pipe going to the wall before snaking?
Got any pictures of that floor drain area?
City sewer, septic?
Old 02-24-2013, 09:52 AM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 994
Call a Plumber before you start renting machines etc, call companies that will quote you over the phone, let them take care of it. take a look at how and why and maybe next time you'll have a little better idea on how to tackle this type of DIY job. no chemicals,, unless your home was re piped its probably cast iron old cast iron at its lifes end, you did more damage than good, also make sure you tell who ever comes out you put acid in that line.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Tags
back up , clogged , need help , plumbing stoppage
Confusing Luxaire GM9 Problem eccentric1 HVAC 11 09-20-2012 08:51 PM
HELP! Confusing 4 way switch dhendriksen Electrical 3 04-15-2012 12:44 PM
Confusing wall switch, neutral wire ? TomK1 Electrical 5 10-04-2011 03:58 PM
Help with Impact and Ratchet Air Wrench Comparison, Confusing Specs donít match caliskier Tools 5 03-15-2009 10:33 PM
