Confusing Situation - Pressure Test - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-07-2012, 11:17 AM   #1
Every year, same time, one day a year the city performs what I believe to be a pressure test on the sewage system. As a result, every year, same time, one day a year this causes my first floor half bath toilet to spray water and the laundry room floor drain to smell of sewer gas. This branch is for my 1/2 bath, laundry tub and laundry floor drain.
Here is my question, why wouldn't the air from the pressure test simply bypass all my fixtures and exhaust out my main stack? I assume I have no blockages, all my fixtures drain with no issue. Could they be pushing so much air that my vents are to small. fyi - the sewage easement runs down the side of my lot.
I must be missing something.
ferris13 is offline   Reply With Quote
Old 03-09-2012, 01:19 PM   #2
Owner
LateralConcepts's Avatar
It wouldn't be a pressure test. The city is most likely doing routine maintenance. Running a high pressure jetter down the city main. When the jetter head comes by your lateral, the pressure is stong enough to force the water in the bowl of your toilet to splash, and after going by it sucks the water from the trap in the floor drain. I would either install a backflow valve in your lateral or simply make sure you keep the lid down on the toilet when city maintenance is scheduled. Likewise, just add a couple cups of water to the dry trap when they're finished to prevent sewer gases from escaping into your home.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
The Following User Says Thank You to LateralConcepts For This Useful Post:
ferris13 (03-12-2012)
rough plumbing pressure test warnerww Plumbing 13 03-29-2011 01:22 AM
Gas Pressure Test - What is good enough spookygeek Plumbing 14 05-19-2010 09:46 AM
Low Well Pressure, Submersible Well Pump, Help Please! tpolk Plumbing 7 11-13-2009 07:13 PM
Carrier pressure switch test spider18 HVAC 2 11-03-2009 05:51 AM
Pressure test water rough-in BillyD Plumbing 2 06-24-2008 03:12 PM
