Confused On To Stub Out Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-28-2009, 07:05 AM   #1
confused on to stub out plumbing
Im confused on the best method to stub out the plumbing in my basement finish bathroom. Here is what the book says for some of its projects, "Use reducing T-fittings to run 1/2" supplies to each fixture, ending with female thread adapters"
So Im wondering 1 if this is the best method, and 2, what I screw in the female thread adapter, as the book ever detail that.
Thanks,
Bryan
bkeech is offline   Reply With Quote
Old 02-28-2009, 10:16 AM   #2
Registered User
Termite's Avatar
I assume we're talking about the vanity sink and water closet, right?
You're better off stubbing up to a shutoff valve for each supply line. That'll require a male threaded pipe or a 1/2" copper for sweat or compression connections. The fixture will connect to the shutoff valve with a pre-made flexible connector.
Want to tile bathroom - raise plumbing? wombosi Plumbing 2 11-13-2008 07:54 PM
missed the plumbing in the slab!!! fauer Plumbing 7 03-03-2008 07:37 PM
Connecting new plumbing into existing plumbing Just do it guy Plumbing 2 02-18-2008 09:36 PM
bent the stub out redneckgeek Plumbing 3 01-07-2008 09:10 AM
new plumbing in kitchen What have I done Plumbing 1 07-29-2006 11:14 AM
