Confused About Water Quality - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-18-2011, 01:05 PM   #1
Rewards Points: 150
Confused about water quality
Our water is yellow, and has a pH of 5.8. We had a softener installed a few months ago ($1200)...water was still yellow. The same guy is now saying that we need an acid neutralizer (another $1200) to help the softener work more efficiently. The yellow color is from moderate iron content (no solids, stays yellow upon standing- does not "settle out". Do you think the neutralizer will remove the yellow color? I'm so confused?
joemontana16 is offline   Reply With Quote
Old 01-18-2011, 01:30 PM   #2
Licensed Master Plumber
Do a water test (untreated) and get back to us. The AN filter will not take out iron. The softener will to some degree
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 01-18-2011, 01:48 PM   #3
Water Treatment
Rewards Points: 900
If the water is staying yellow and nothing is dropping down to the bottom then to me that says tannin.
If the ph is down at 5.8 then there is going to be the need of some form of correction to bring the ph to 7.2.
Standard softeners will do nothing to remove color or correct the ph.
Akpsdvan is offline   Reply With Quote
Old 01-19-2011, 08:52 AM   #4
Rewards Points: 150
Is there a way to remove tannins? I know our water is safe...but my wife hates putting the baby in yellow bath water.
Old 01-19-2011, 11:43 AM   #5
Yes, tannins can be removed. Here is a link to an online supplier (provided as an example--not a recommendation of the specific site) that shows some of the equipment available.
http://www.ohiopurewaterco.com/shop/...me.php?cat=217
If you have copper plumbing the pH of 5.8 is a serious problem becuase the acid water will leach copper from the pipes--probably increasing the copper content above recommending levels and in time causing pin hole leaks in your copper pipes. AN filters are also available from online suppliers--look around the website I linked to above for examples
Bob999 is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Gas Water Heater, water not hot enough - Thermostat or Sediment makunag Plumbing 15 08-27-2010 11:00 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 10:24 AM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 10:29 PM
