Confused about toilet flushing features
Hi, I'm a first time poster, long time pooper.
I've had the same Kohler Devonshire toilet for a long time. I found the model number and it's K-4269, in case anyone's familiar. My issue, which has gotten worse over the years, is that my stools are too large to even exit the bowl sometimes. When they do exit the bowl, they'll get stuck and the toilet will plug up anyhow. It's not at all a toilet paper issue. I guess I am a freak of nature (I've already been to a gastroenterologist for this, and they had no help, in fact he said it was a good sign). So, I'm wondering if a toilet with a more powerful flush can help push something through that's too big, or if the only solution is a bigger hole for the substance to go through. I've looked at Kohler and American Standard's websites. They have too many options. I see that American Standard has a toilet with a 2 3/8" trapway both in the Champion 4 and Champion Pro. But my toilet I have now is 2". Would that extra 3/8" really make a difference. And then there also different flushing technologies. Kohler has a Pressure Lite and a Power Lite. American Standard seems to just advertise that theirs are more powerful by design due to a larger flush valve. I'm just generally rather confused and don't know much about this subject. I'm open to all ideas on this. This has started causing family fights and it's generally unpleasant to deal with this on a daily basis. Thank you! |
Nothing to be embarrassed about, what I'd recommend is a Flushmate pressure assisted toilet. As America gets larger (read obese) so do the stools. The Flushmate uses pressure and a slightly different design to assure a complete flush nearly every time. google it to find a distributor near you. It's one of the best purchases WE ever made.
DM |
Take a look at these videos
http://www.youtube.com/watch?v=gaWDH16SqVs http://www.americanstandard-us.com/v...=1452773060001 current record is 29 golf balls. The top rated flushers are the American Standard Champion 4 and Kohler Cimarron K3609. We got the Champion 4. |
Before you bought the Champion 4, did you look at the Champion Pro, and if so, what did you think about the differences? There was a video on the American Standard Facebook page explaining the differences (not sure how if the Facebook link will work, but here it is): http://www.facebook.com/photo.php?v=3570608148485 They sound largely the same; however, the Pro is 1.28 GPF while the 4 is 1.6 GPF. The Pro is supposed to also rinse the bowl better. Also, the Pro uses metal in the shank (not sure what that is?) and trip lever (is that the flusher?), whereas the 4 is made of plastic in those parts. I like the part about the Pro being built of metal, but I would think the 1.6 GPF would make the 4 more powerful; although they claim the Pro is just more efficient with water (although I've heard that story before). I tried researching the Kohler you mentioned, and Kohler's web-site is a bit harder to navigate. They publish the trapway and flush valve size of the lower end Cimmaron (2 1/8" and 3" respectively, less than the Champion), but they don't advertise the sizes on the model you listed, which seems to be the higher end "Class 5" Cimmaron. There's also an interesting parallel between the higher end Cimmaron and Champion; both of the higher end models (or what I assume are the higher end models, the "Class 5" models for Kohler, and the Champion Pro for American Standard) actually use less water per flush and both advertise that they clean the bowls better. I wish this were like computers, where I have a better grasp on all these different factors. I think I would tend to go with American Standard over Kohler because of the trapway size and also because of having had a bad experience with a Kohler toilet seat in the past, but knowing the details between the Champion 4 and Champion Pro, which would you buy if you were in the market again? Thank you again for your help. |
Sorry to post so much but in my research I've come across some more information by way of a site called terrylove.com The person who runs that site thinks a lot of Toto toilets (especially the Guinevere) which have a cyclone flushing technology, but it seems to only have a 2 1/8" trapway.
I also found a thread on his site where he recommended Caroma USA toilets which apparently have a 4" trapway. Although, I've seen other threads that say they aren't so good because of having a small "water spot" which means a messier toilet bowl. But a 4" trapway sounds pretty good! |
I picked American Standard over Kohler for 3 reasons: I'm 50 and have always had an American Standard toilet; as you mentioned the web site was definitely friendlier and more informative; and we had already decided on an American Standard tub/shower. We essentially were able to upgrade to the Champion 4 for free, because the web site offered free LTL shipping at $1500 and our shopping cart with the Cadet 2 came to just under $1500 with shipping. |
DM |
| All times are GMT -4. The time now is 05:10 AM. |
