Old 11-24-2010, 09:31 PM   #1
Send a message via AIM to chsitko Send a message via Yahoo to chsitko
Configuration of 2 ball valves on Sump Discharge Line
I currently have one output line for my sump discharge. I want to be able to direct the sump discharge to 2 different locations when needed. To accomplish this im going to add another discharge line and connect it to the existing line. After the split i want to add a valve one each line to control the discharge to both lines if needed, or select one over the other if needed. Is there any rules as to where these valves should be placed? Do they need to be Vertical or Horizontal. I attached 2 pictures to illustrate my 2 options. Whats the best choice
chsitko is offline   Reply With Quote
Old 11-24-2010, 09:52 PM   #2
they should be as close to the check valve as possible
the_man is offline   Reply With Quote
Old 11-25-2010, 09:13 AM   #3
Ok, i will place them as close to the check valve as possible. What is the reasoning for this?
Also, does it mater if they are horizontal or vertical. If i put them close to the check valve they will be vertical. Does that cause any problems with Air getting trapped?
Chris
Old 11-25-2010, 10:13 AM   #4
so you can easily service the check valve without draining the discharge pipe
ball valves: sweat vs threaded Steve_P Plumbing 16 08-24-2010 10:29 AM
check out the new ball valves! wombosi Plumbing 7 02-03-2009 10:00 PM
Question about sump pumps and check valves lennyseleven Plumbing 3 11-08-2007 11:33 AM
Sweating Ball Valves 47_47 Plumbing 7 10-21-2007 09:13 PM
running the sump pump to the sewer line Jack Hass Plumbing 9 11-02-2006 10:36 AM
