Conducting Water Supply To Detached Garage - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-28-2008, 12:58 PM   #1
Rewards Points: 1,062
Question
conducting water supply to detached garage
can somebody shed some light on running pipe underground from a house to a detached garage/shed, i.e. what all is needed to prevent freezing ? some type of insulation, i presume.
thanks,
- a -
Old 02-28-2008, 02:53 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,060
Ayuh,....
No insulation should be needed,....
It depends on Where you live......
The farther North,.. The Deeper you Dig......
Up in this country,.. about 4' is usually enough,.... 6' if it's crossing a driveway.....
And,...
If you're not coming back Up into a heated structure,....
Get yourself a Frost-Proof hydrant......
Bondo is online now   Reply With Quote
Old 02-28-2008, 03:02 PM   #3
washington DC
if NY is 4 ft, DC shouldn't need deeper than 3, huh ?
so basically, just bury the pipe with nothing surrounding it, as if it were inside ?
Old 02-28-2008, 03:03 PM   #4
Question
of course, i am not heating the garage
what is a frost-proof hydrant ?
Old 02-28-2008, 03:08 PM   #5
Question
is a frost-proof hydrant a glorified sillcock ?
so even if i bury the water line 3 ft under, it eventually will come out into an unheated garage. what do i do to prevent it from freezing there, if any (other than heat) ?
Old 02-28-2008, 03:14 PM   #6
Question
or should i say
is there a break-resistant special pipe i should get that will at least prevent breakage amid freezing ?
Old 02-28-2008, 04:24 PM   #7
Rewards Points: 1,910
check your building dept for correctdepth.
A frost proof hydrant (you can find at many farm supply stores) has the actual valve mechanism below the frost depth and is set in gravel. A vertical pipe with outlet and valve control handle come out of the ground. When you shut off the water, the excess in the verticel pipe drain into the gravel. That way nothing freezes as everthing is below the frost level.
Check with your building dept regarding approved pipe but freezing is not an issue because it is below frost depth.
Old 02-28-2008, 06:38 PM   #8
Question
also
i will have a single faucet at the end, maybe tow maximum (if i decide to have one inside and one outside). normally, if it were indoors, 1/2 pipe would suffice. since i am going outside and burying, any reason to go bigger, e.g. 3/4 ?
thanks,
- a -
Old 02-29-2008, 07:54 AM   #9
Bondo's Avatar
Ayuh,....
For the underground run I would use 1" Black Plastic Pipe,......
And,.....
If you use Anything but the Frost-proof Hydrant,.....
You're going to have to manually Drain everything above the frost line.....
Probably including the plumbing inside the shed....
Old 02-29-2008, 08:01 AM   #10
What will the water be used for?
PEX?
redline is offline   Reply With Quote
Old 02-29-2008, 10:33 AM   #11
not copper ?
Old 02-29-2008, 10:34 AM   #12
i do plan to use a Frost-proof Hydrant. any other suggestions ?
Old 02-29-2008, 10:35 AM   #13
carwash and other miscellaneous around-the-shed applications. not drinking.
Detached Garage Sub Panel Grounding Q integlikewhoa Electrical 15 03-12-2015 07:02 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 01:46 PM
advice on cold water pipe in basement garage area cambie Plumbing 6 10-15-2008 01:29 PM
detached garage Kapt Electrical 12 01-17-2007 08:37 AM
