-   -   conducting water supply to detached garage (http://www.diychatroom.com/f7/conducting-water-supply-detached-garage-17790/)
amakarevic 02-28-2008 12:58 PM
can somebody shed some light on running pipe underground from a house to a detached garage/shed, i.e. what all is needed to prevent freezing ? some type of insulation, i presume.
thanks,
- a -
Bondo 02-28-2008 02:53 PM
Ayuh,....
No insulation should be needed,....
It depends on Where you live......
The farther North,.. The Deeper you Dig......
Up in this country,.. about 4' is usually enough,.... 6' if it's crossing a driveway.....
And,...
If you're not coming back Up into a heated structure,....
Get yourself a Frost-Proof hydrant......
amakarevic 02-28-2008 03:02 PM
washington DC
if NY is 4 ft, DC shouldn't need deeper than 3, huh ?
so basically, just bury the pipe with nothing surrounding it, as if it were inside ?
amakarevic 02-28-2008 03:03 PM
of course, i am not heating the garage
what is a frost-proof hydrant ?
amakarevic 02-28-2008 03:08 PM
is a frost-proof hydrant a glorified sillcock ?
so even if i bury the water line 3 ft under, it eventually will come out into an unheated garage. what do i do to prevent it from freezing there, if any (other than heat) ?
amakarevic 02-28-2008 03:14 PM
or should i say
is there a break-resistant special pipe i should get that will at least prevent breakage amid freezing ?
jogr 02-28-2008 04:24 PM
check your building dept for correctdepth.
A frost proof hydrant (you can find at many farm supply stores) has the actual valve mechanism below the frost depth and is set in gravel. A vertical pipe with outlet and valve control handle come out of the ground. When you shut off the water, the excess in the verticel pipe drain into the gravel. That way nothing freezes as everthing is below the frost level.
Check with your building dept regarding approved pipe but freezing is not an issue because it is below frost depth.
amakarevic 02-28-2008 06:38 PM
also
i will have a single faucet at the end, maybe tow maximum (if i decide to have one inside and one outside). normally, if it were indoors, 1/2 pipe would suffice. since i am going outside and burying, any reason to go bigger, e.g. 3/4 ?
thanks,
- a -
Bondo 02-29-2008 07:54 AM
Ayuh,....
For the underground run I would use 1" Black Plastic Pipe,......
And,.....
If you use Anything but the Frost-proof Hydrant,.....
You're going to have to manually Drain everything above the frost line.....
Probably including the plumbing inside the shed....
redline 02-29-2008 08:01 AM
What will the water be used for?
PEX?
amakarevic 02-29-2008 10:33 AM
not copper ?
amakarevic 02-29-2008 10:34 AM
i do plan to use a Frost-proof Hydrant. any other suggestions ?
amakarevic 02-29-2008 10:35 AM
carwash and other miscellaneous around-the-shed applications. not drinking.
