Condo Washer Drain Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-03-2013, 04:33 PM   #1
Condo washer drain pipe
Hi There,
I recently purchased a new condo, as well as a new washer/dryer.
Everything hooks up great, but the drain pipe overflows throughout the wash. It drains, but cant handle the outflow. For curiosity sake, I rammed a coat hanger down the pipe reaching a solid obstruction about 4 feet down, no matter how I turned the hanger.
What is my next step? Drano? I'd assume snaking it wouldn't make sense considering the blockage?
struggles is offline   Reply With Quote
Old 06-03-2013, 05:16 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 922
You may be hitting the trap inside the wall- at the base of the stand pipe or the tee where the trap intersects the drain.
I'd cable it just for giggles.
How old is the place and are the pipes exposed? Is the trap vented?
Old 06-03-2013, 05:23 PM   #3
Thanks for the reply!
The condo is about 10 years old on the second level, the pipe's are not exposed. If there is a vent, I cannot see it.
Old 06-04-2013, 06:26 PM   #4
Rewards Points: 2,108
Did you switch from a top load washer to a front load unit?
Ghostmaker is online now   Reply With Quote
Rusted and almost gone drain pan, Package unit Nordyne kilosos2 HVAC 3 11-18-2012 09:24 AM
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 06:52 PM
drain pipe from HVAC in attic dripping on to sheetrock gnostic19 HVAC 7 03-22-2011 03:05 PM
Adding washer to basement with no way to vent drain pipe General Plumbing 6 12-26-2010 11:11 AM
Water heater drain pan - can I drain into the washer drain? cjartguy Plumbing 7 04-15-2009 02:34 PM
