Old 07-26-2012, 06:54 PM   #1
Condesate Pump physics
Is it ok for me to collect water pumped from a condesate pump into a bucket to use for watering plants? I was just told that the laws of physics state I could cause the water to back up if I do this.
Yamaha52 is offline   Reply With Quote
Old 07-26-2012, 07:05 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
If you are talking about using something like a rain barrel, just attach something to allow the excess at a certain level, to drain off.
Depending on the output, will determine how fast you fill up the bucket.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 07-26-2012, 07:28 PM   #3
I have a small condesate pump pumping water from my dehumidifier up to the sink in my laundry room. I placed the drain hose inside a 3 gallon pitcher to collect water for my plants during this drought. I was told that this could cause the water to back up back into the pump if the drain hose was immersed in water. I'm trying to find out if this is not a good practice.
Old 07-26-2012, 08:45 PM   #4
gregzoll's Avatar
Just have the hose a little higher than the pitcher. Anything that overflows, would just pour over the top, and the hose really does not need to be immersed, just needs to be able to pour into the container.
Old 07-26-2012, 09:07 PM   #5
Thumbs up
That makes sense! A simple solution. Thanks so much!!
Intermittent submersible pump fault esquilax Electrical 5 09-30-2011 04:56 AM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 07:10 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
Sump Pump Questions henlij Plumbing 19 08-12-2009 08:50 PM
condesate pump drainage horsenutz39 HVAC 4 08-03-2009 10:00 PM
