Condensing Tankless Water Heater: Navien, Noritz, Bosch - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-07-2012, 04:48 PM   #1
condensing tankless water heater: navien, noritz, bosch
folks,
can i get some feedback on experiences with natural gas 'condensing' tankless water heaters?
i need one of the bigger units, 199,000btuh, to handle about 3showers, worst case, in northern nj (they say winter water temp = 45deg), and if i assume 120F output, that's a 75deg rise.
if all that seems reasonable, it says i could get by with either of these:
- noritz nrc1111 dv-ng
- navien nr-240a
- bosch c1210es
if you compare flow rate graphs, it seems the navien is the best.
now, over at the plumbingzone, both navien (in the past) and bosch, seem to be 'disliked'. but i don't know if any of that still applies to these units? maybe navien and bosch have licked their problems?
does anyone have experience with these units? or maybe a preference based on experience with a couple of them? or maybe a different condensing unit manufacturer that has really impressed you?
thanks,
ron
rny1diyc is offline   Reply With Quote
Tags
bosch tankless , navien , noritz
Tankless water heater to pre-heat incoming water matthet Plumbing 35 01-06-2017 12:39 AM
REplacing water heater - PV, DV, or Tankless? curls00 Plumbing 5 12-09-2010 12:21 PM
One Tankless Water Heater for Hydronic & Potable? VIPSpecialNeeds Plumbing 3 07-30-2009 03:09 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
