Old 10-12-2010, 01:57 PM   #1
EkS
Exclamation
Condensation on ceiling near water heater.
Just noticed that there's condensation on the ceiling and part of the wall near a water heater that's inside the house in the laundry room. I believe it's coming from the water heater because I can see some condensation going up the wall from the water heater closet.
The weird thing about this is that there is NO condensation inside the water heater closet or on the water heater itself. I notice it after taking a shower, so the water heater turns on.
My question is how can I verify that the water heater is the problem? If that's the problem why is it happening and how can I fix it?
EkS is offline   Reply With Quote
Old 10-12-2010, 02:36 PM   #2
steveel's Avatar
check to make sure the flue is neither broken nor blocked; when natural gas burns a large part of the gas turns to water vapor; it will condense as it cools
steveel is offline   Reply With Quote
Old 10-12-2010, 02:42 PM   #3
EkS
Thank for the tip, I'll do that. But why won't there be any condensation inside the water heater closet?
Old 10-12-2010, 02:47 PM   #4
steveel's Avatar
This is just a guess, but maybe lost heat from the water heater keeps the closet temp above dewpoint. All other things being equal, just one degree temp difference can determine whether condensation happens or not.
BTW, suggest you don't delay checking the flue. The gases also contain deadly odorless carbon monoxide.
Old 10-12-2010, 02:52 PM   #5
EkS
Got it on checking the flue, doing that today. Speaking of carbon monoxide buying a detector too!
Any other possibilities/guesses?
Old 10-12-2010, 11:48 PM   #6
EkS
Well bought a carbon monoxide detector.
So I got on the roof and checked out the flue. First thing I noticed is that the cap is for a 4 inch pipe and the pipe I have is 3 inch. So the cap was actually blocking the flow of air. As a temp. fix I just duct taped the cap on right, and I actually could fell the hot air escaping. So we'll see if this works tomorrow morning.
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 11:33 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
