Condensation On Bottom Of The Toilet Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-16-2013, 11:02 AM   #1
hohadcr's Avatar
Rewards Points: 306
Condensation on bottom of the toilet tank
Hi, In one of the bathrooms at my friends, I saw water dripping down the toilet tank.. Then I realized that the water came from the condensation... Please see the pic.
Ignore the mess around the toilet...:!
What is wrong?
Condensation on bottom of the toilet tank-img_20130314_120537.jpg   Condensation on bottom of the toilet tank-img_20130314_120546.jpg
hohadcr is offline   Reply With Quote
Old 03-16-2013, 11:06 AM   #2
Rewards Points: 13,300
Room is to humid.
Do they have a ceiling fan and use it?
Old 03-16-2013, 11:16 AM   #3
Lord of Slums
Rewards Points: 1,974
You could run hot water to the toilet, bit wasteful but would fix the problem. Not sure if their is a way to insulate the tank
mj12 is offline   Reply With Quote
Old 03-16-2013, 11:53 AM   #4
Roofmaster
Rewards Points: 2,172
Mixing valve to temper the water. Well water I presume?
Old 03-16-2013, 11:55 AM   #5
Rewards Points: 230
Maybe a small fan by the toilet for some air circulation or dehumidifier for quick fix. They make a tempering valve which is installed on your toilet supply line. It mixes hot and cold water to prevent sweating. However, you would have to have access to hot water which most people do not have running to their toilets.
jmon is offline   Reply With Quote
Old 03-16-2013, 12:19 PM   #6
Roofmaster
Jmon, so with a Bidet you mean they squirt their privates with well water????? Man, talk about a rude awakening! That would definately make tommy the turtle pull his head into his shell!
The Following User Says Thank You to jagans For This Useful Post:
jmon (03-16-2013)
Old 03-16-2013, 12:20 PM   #7
Rewards Points: 194
Really there's nothing wrong, it's just the cold water coming in from outside causing your toilet tank to get very cold creating condensation from the humid air in your bathroom on the tank. In the summer this doesn't happen because the water coming into the house is warmer. Toilet tanks can be purchased insulated to help with this issue.
Larryh86GT is offline   Reply With Quote
Old 03-16-2013, 02:12 PM   #8
Rewards Points: 1,772
Put some food dye into your tank. If any gets to the bowel without flushing your tank is leaking. You will need to replace the tank flush valve flapper.
What is happening is your water is constantly being replaced and it is cold...
Old 03-16-2013, 02:17 PM   #9
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Is the toilet running? Typically toilet tanks sweat when the fill valve is running, or in winter if the room is kept very hot in comparison to the incoming water.
Journeyman Plumber
Old 03-30-2013, 09:30 AM   #10
hohadcr's Avatar
Rewards Points: 306
The toilet is running. This bathroom is inside of the house, and is kept room tempreture.
So I think I should replace the tank flush valve flapper first to see.
Old 03-31-2013, 11:55 AM   #11
Doing it myself
Alan's Avatar
You shouldn't need to replace the flush valve.
Replace the fill valve and the flapper. Feel around the edge of the flush valve when you have the flapper off to see if there are any imperfections, rough spots, etc that would cause the flapper not to seat properly. If you don't feel anything strange, the flush valve should be OK.
I've had a couple of rare occasions where the overflow tube attached to the fill valve was cracked. I was only able to detect that by filling the tank, turning off the water and watching down the overflow tube with a flashlight. Rare in my experience though.
Journeyman Plumber
Old 04-03-2013, 05:13 PM   #12
hohadcr's Avatar
Rewards Points: 306
I have changed the flapper, bolts from tank to toilet, and the central gasket.
The only that wasn't changed was the fill/waterflow tube.
The condensation is still there. only around where the water inflow is, only that corner.
So, I need to change the last pieces as well..?
Old 04-03-2013, 07:15 PM   #13
Bill Kearney
Rewards Points: 1,174
Is the water continuing to run? Or does it fill and shut off properly? If left off and filled, does condensation form on it?
The water should not continue to run once the tank is full. If it keeps running then it will condense like that.
What's the room temperature being kept at? What's the water temp? Just how cold is it?
wkearney99 is offline   Reply With Quote
Old 04-03-2013, 08:34 PM   #14
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,024
If it is still running, it will continue to dump cold water into the tank and it will continue to sweat.
Old 04-03-2013, 09:14 PM   #15
hohadcr's Avatar
Rewards Points: 306
Doesn't seem to be running though.... The shut off works properly as well.
Room temp is about 65 degrees. water temp, unknown. We have city water, we are in a dense city area.
toilet tank fills even after wall valve shut off msmitymite Plumbing 9 09-11-2016 10:21 AM
one toilet bolt is missing and water is leaking out from bottom of toilet don1949 Plumbing 1 05-07-2012 11:38 AM
Can I replace just the tank on a toilet? gma2rjc Plumbing 7 03-06-2011 09:14 PM
whistling toilet tank fill problem Need Advice Plumbing 6 01-16-2011 09:13 PM
Piece on bottom of toilet tank won't seal Squeeealer Plumbing 1 07-14-2005 09:13 PM
