-   -   Condensation on bottom of the toilet tank (http://www.diychatroom.com/f7/condensation-bottom-toilet-tank-174661/)
hohadcr 03-16-2013 11:02 AM
2 Attachment(s)
Hi, In one of the bathrooms at my friends, I saw water dripping down the toilet tank.. Then I realized that the water came from the condensation... Please see the pic.
Ignore the mess around the toilet...:!
What is wrong?
joecaption 03-16-2013 11:06 AM
Room is to humid.
Do they have a ceiling fan and use it?
mj12 03-16-2013 11:16 AM
You could run hot water to the toilet, bit wasteful but would fix the problem. Not sure if their is a way to insulate the tank
jagans 03-16-2013 11:53 AM
Mixing valve to temper the water. Well water I presume?
jmon 03-16-2013 11:55 AM
Maybe a small fan by the toilet for some air circulation or dehumidifier for quick fix. They make a tempering valve which is installed on your toilet supply line. It mixes hot and cold water to prevent sweating. However, you would have to have access to hot water which most people do not have running to their toilets.
jagans 03-16-2013 12:19 PM
Jmon, so with a Bidet you mean they squirt their privates with well water????? Man, talk about a rude awakening! That would definately make tommy the turtle pull his head into his shell!
Larryh86GT 03-16-2013 12:20 PM
Really there's nothing wrong, it's just the cold water coming in from outside causing your toilet tank to get very cold creating condensation from the humid air in your bathroom on the tank. In the summer this doesn't happen because the water coming into the house is warmer. Toilet tanks can be purchased insulated to help with this issue.
Ghostmaker 03-16-2013 02:12 PM
Put some food dye into your tank. If any gets to the bowel without flushing your tank is leaking. You will need to replace the tank flush valve flapper.
What is happening is your water is constantly being replaced and it is cold...
Alan 03-16-2013 02:17 PM
Is the toilet running? Typically toilet tanks sweat when the fill valve is running, or in winter if the room is kept very hot in comparison to the incoming water.
hohadcr 03-30-2013 09:30 AM
The toilet is running. This bathroom is inside of the house, and is kept room tempreture.
So I think I should replace the tank flush valve flapper first to see.
Alan 03-31-2013 11:55 AM
You shouldn't need to replace the flush valve.
Replace the fill valve and the flapper. Feel around the edge of the flush valve when you have the flapper off to see if there are any imperfections, rough spots, etc that would cause the flapper not to seat properly. If you don't feel anything strange, the flush valve should be OK.
I've had a couple of rare occasions where the overflow tube attached to the fill valve was cracked. I was only able to detect that by filling the tank, turning off the water and watching down the overflow tube with a flashlight. Rare in my experience though.
hohadcr 04-03-2013 05:13 PM
I have changed the flapper, bolts from tank to toilet, and the central gasket.
The only that wasn't changed was the fill/waterflow tube.
The condensation is still there. only around where the water inflow is, only that corner.
So, I need to change the last pieces as well..?
wkearney99 04-03-2013 07:15 PM
Is the water continuing to run? Or does it fill and shut off properly? If left off and filled, does condensation form on it?
The water should not continue to run once the tank is full. If it keeps running then it will condense like that.
What's the room temperature being kept at? What's the water temp? Just how cold is it?
Windows on Wash 04-03-2013 08:34 PM
+1
If it is still running, it will continue to dump cold water into the tank and it will continue to sweat.
hohadcr 04-03-2013 09:14 PM
Doesn't seem to be running though.... The shut off works properly as well.
Room temp is about 65 degrees. water temp, unknown. We have city water, we are in a dense city area.
