Old 01-04-2009, 04:57 PM   #1
concrete sink help!
My husband and I, who are very new to home improvement, recently made a bathroom counter with inlaid sinks from concrete. Everything turned out great, however now that we hooked up the water we noticed that a little bit of water stays on the bottom of the sinks. It doesn't drain because the edges of the drain stick up just a little bit higher than the bottom of the sink. Is there some type of product that can level it out,maybe some typy of clear plastic that we could put around the drain to even things out??
Hope I explained this clearly!
thanks,
Nicole
nicoleb is offline   Reply With Quote
Old 01-04-2009, 07:36 PM   #2
Master General ReEngineer
Bondo's Avatar
concrete sink help!
Ayuh,...
I think that carving a pocket in the basin to accept the tail piece, would be better than flooding the low spots with epoxy...
Concrete can be carved with grinders like Dremils, Roto-zips, diegrindes, etc...
Old 10-13-2012, 12:29 PM   #3
concrete sink help!
I seen your post and do not claim to be a plumber or engineer but
what if you were to remove the drain and grind the entire surface down so the low spots are draining correctly
Hope you have luck with it
Bob Landry is offline   Reply With Quote
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 06:53 PM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 09:43 AM
Pedestal sink - alternative to anchoring to concrete floor? aktheda Plumbing 2 03-19-2008 02:12 PM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
