Concrete Platform Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-29-2007, 01:31 PM   #1
Rewards Points: 1,062
Question
concrete platform toilet
i am building a bathroom in my basement. the floor is concrete. i haven't poured concrete in the bathroom area yet and was wondering whether the toilet flange should be flush with
1) the concrete level
2) the future tile level
also, was wondering whether the flange should be set before concrete is poured OR should i leave some leeway around using a sleeve or something like that to set it AFTERWARDS ?
thx,
- a -
Old 12-29-2007, 01:35 PM   #2
on top of the finnished floor. secured to it.
what type of pipe??
ranman469 is offline   Reply With Quote
Old 12-29-2007, 01:47 PM   #3
Question
PVC. so are you saying i should leave some space around the outlet (make a sleeve around and give it a few inches) when pouring concrete ? i can pour patcher in the end.
Old 12-29-2007, 01:52 PM   #4
is it 3" or 4"?
if its 3" yes leave a space for the ring to glue on.
if 4" you can get a flange to glue inside the 4"
when i plum a bath i install a 3x4 90 fo the toilet and stub up 4" finish the floor around the pipe, then cut flush with the floor, and install the inside flange.
Old 12-29-2007, 01:55 PM   #5
Exclamation
it is 3". thanks very much for your insight
Old 12-29-2007, 02:05 PM   #6
cool. have fun
Old 12-29-2007, 02:56 PM   #7
Send a message via AIM to Marlin
Make sure you can use plastic to come up through concrete, and that it's ok to use plastic underground. That isn't allowed in some places (NY for example).
They do make three inch street flanges, they don't only come in 4in.
Marlin is offline   Reply With Quote
Old 12-29-2007, 03:05 PM   #8
wow no pvc underground in NY? learn something new everyday
a 3" street flange will sometimes hit the horn on the bottom of the w/c. i have had that problem before. it was a pain to fix.
some brands fit difrently.
http://www.jupiterheating.com/pdfs/s...ef-tkobrch.pdf
Old 12-29-2007, 04:07 PM   #9
Let me catch myself here. It's no PVC underground in my county as well as a couple others I know of. It's not universal throughout NY.
Old 12-29-2007, 05:59 PM   #10
Master Plumber
Rewards Points: 150
A flange to glue inside of 3" pipe is available but is not a street fitting, street is pipe size, these flanges are reduced under 3" diameter (the smallest allowed for toilet waste) and are not sch.40.
jpplumber is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 09:38 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 04:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
