Concentric Vent Retrofit - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-17-2012, 03:43 PM   #1
Hi there. I have a gas hot water tank which vents through a 2" concentric vent on an outside wall. The vent is PVC and is connected to the existing hot water tank with ABS pipe. I'm changing the venting system to CPVC (System 636) in advance of a hot water tank swap-out and trying to figure out if I can re-use the existing wall vent.
My thoughts around options were:
  1. Cut the ABS pipe near the vent, leaving a small stub of ABS with which I could attach a union using ABS / CPVC transition cement. This would make my life easy but might not address the code requirement in my jurisdiction (Alberta) for CPVC venting.
  2. Try to find the "Y" piece (on the interior side) for a concentric vent and retrofit the actual vent piece. All I see for sale are complete vent kits, which suggest to me that cutting a vent kit apart may be easier said than done. I can only imagine that cutting and deburring may create more risk to my new boiler than is advisable.
  3. Replace the vent altogether. The vent is only 11 years old, and I'm avoiding replacing it completely more out of the pain-in-the-neck factor than cost.
If anyone has any advice on how to proceed I'd appreciate it.
benchlands is offline   Reply With Quote
Old 12-17-2012, 10:51 PM   #2
Rewards Points: 630
why not cut the abs out of the hub (socket) of the vent and glue cpvc back in
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 12-18-2012, 12:24 AM   #3
Never even thought of that! What's the best way to cut the piece of abs out? Is there a special tool?
Old 12-18-2012, 03:42 PM   #4
Roofmaster
Rewards Points: 2,172
Why are you farting around with trying to Rube Goldberg something that is done wrong could kill you and your family while you sleep? There is frugal, like me, and there is regretfully cheap. Which are we going to be?
Old 12-18-2012, 05:48 PM   #5
Rewards Points: 630
yes they make a few tools that will do this they are called ram bits. but i would be shocked if you would need them they will probably just pull apart since abs and pvc do not weld (glue) together correctly
http://www.pascospecialty.com/catalo..._CATALOG_C.pdf
Tags
abs , concentric , cpvc , vent
Installing a gable vent..from *inside* the attic steveKane Building & Construction 8 12-09-2012 03:45 PM
Water Heater Vent Question pd417 Plumbing 1 05-15-2010 01:34 PM
finishing a basement bath - tie in to ejector pump vent? ajbowman Plumbing 7 04-15-2008 01:09 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 07:33 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 07:34 PM
