-   -   Concentric Vent Retrofit (http://www.diychatroom.com/f7/concentric-vent-retrofit-166715/)
benchlands 12-17-2012 02:43 PM
Hi there. I have a gas hot water tank which vents through a 2" concentric vent on an outside wall. The vent is PVC and is connected to the existing hot water tank with ABS pipe. I'm changing the venting system to CPVC (System 636) in advance of a hot water tank swap-out and trying to figure out if I can re-use the existing wall vent.
My thoughts around options were:
  1. Cut the ABS pipe near the vent, leaving a small stub of ABS with which I could attach a union using ABS / CPVC transition cement. This would make my life easy but might not address the code requirement in my jurisdiction (Alberta) for CPVC venting.
  2. Try to find the "Y" piece (on the interior side) for a concentric vent and retrofit the actual vent piece. All I see for sale are complete vent kits, which suggest to me that cutting a vent kit apart may be easier said than done. I can only imagine that cutting and deburring may create more risk to my new boiler than is advisable.
  3. Replace the vent altogether. The vent is only 11 years old, and I'm avoiding replacing it completely more out of the pain-in-the-neck factor than cost.
If anyone has any advice on how to proceed I'd appreciate it.
jaydevries 12-17-2012 09:51 PM
why not cut the abs out of the hub (socket) of the vent and glue cpvc back in
benchlands 12-17-2012 11:24 PM
Never even thought of that! What's the best way to cut the piece of abs out? Is there a special tool?
jagans 12-18-2012 02:42 PM
Why are you farting around with trying to Rube Goldberg something that is done wrong could kill you and your family while you sleep? There is frugal, like me, and there is regretfully cheap. Which are we going to be?
jaydevries 12-18-2012 04:48 PM
yes they make a few tools that will do this they are called ram bits. but i would be shocked if you would need them they will probably just pull apart since abs and pvc do not weld (glue) together correctly
http://www.pascospecialty.com/catalo..._CATALOG_C.pdf
