Originally Posted by plummen
is the other end of the line removable to slide the nut over or does it already have the nut on the tube?
Well, I had hoped that it would be - turns out it connects directly into the (Delta)faucet itself! I guess they want you to buy a whole new faucet
I was going to just remove that line and put in a flex hose or slide the new nut/ferrul over it.
So i guess the question now is - since I (apparently) can't remove the old single line from the faucet itself - can it be sawed into and fitted with a piece of flex hose?
Or, the option you suggested which was to cut the very bottom of the old line off and attach there. There seems to be enough length to do that - I'm worried that without that ring the fitting won't hold tight enough. What do you think?
