Composite Granite Sink/ Garbage Disposal Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-27-2011, 09:13 AM   #1
Composite granite sink/ garbage disposal leak
I installed a H.D. composite granite sink for a friend, the garbage disposal keeps leaking under the flange that the disposal attaches to. I used the alternate plumbers putty recommended for granite. Friend does not want silicone used,heard of problems with it. (?) I have made 3 trips attempting to stop this leak. I know on a metal sink the 3 screws that attach the disposal on the underside get screwed all the way in, Being that the "granite" is thicker they only screw half way in before popping the ring off, of course causing the disposal to fall. I would love some advice to get this fixed finally. Thanks.
mickhubb is offline   Reply With Quote
Old 11-27-2011, 09:33 AM   #2
DIY staff
Rewards Points: 7,174
What brand? Insinkerator? If so there are shorter screws available--
Old 11-27-2011, 11:55 AM   #3
It is a Badger 2hp?
Old 11-27-2011, 12:04 PM   #4
DIY staff
That's an Insinkorator----Get the shorter screws---use regular plumbers putty--that is a fake granite and will not stain----make sure the rubber washer is against the sink bottom----then the card board one---
I don't ever use silicone and have never had one leak----Good luck---Mike----
mickhubb (11-27-2011)
Old 12-17-2011, 11:30 AM   #5
figured the problem out finally..
The problem all along was the customer bought an after market flange for the drains. The recess on garbage disposal side flange was not deep enough to properly seat the c-snap ring. Once a properly designed one was purchased the screws also went all the way in as I knew it should be. Lesson learned, Headache solved, thanks for the input!
The Following 2 Users Say Thank You to mickhubb For This Useful Post:
ben's plumbing (12-17-2011), oh'mike (12-17-2011)
Tags
composite granite sink , garbage disposal leak
Clogged Garbage Disposal Dave in Michigan General DIY Discussions 2 08-08-2011 12:35 PM
not using garbage disposal with sink intended for one amakarevic Plumbing 3 07-19-2011 06:53 AM
Extra deep sink not working with disposal cWilson Plumbing 3 11-22-2010 11:55 AM
cast iron sink over granite Garbo Kitchen & Bath Remodeling 1 11-09-2010 04:38 PM
Garbage Disposal Dilemma (with pic) tommy potatoes Plumbing 13 03-23-2009 05:50 PM
