Old 01-21-2011, 10:08 AM   #1
Completing Roughed in basement bathroom
Hi guys,
i wanted some input on how to tie a new drain into the existing roughed in work already done. From the picture i have drawn a line from where the new pvc pipe will come from. I know that it needs to be vented as well, so i guess the single pipe at some point will be "T'd" off. Any ideas on how this should be done?
Thanks in advance.
PHomeOwner is offline   Reply With Quote
Old 01-21-2011, 10:13 AM   #2
That all depends.. What are you running it to? Sink? Laundry? Bar?
Docwhitley is offline   Reply With Quote
Old 01-21-2011, 10:14 AM   #3
this is running from a new sink that i will be putting in.
Old 01-21-2011, 10:21 AM   #4
Well then my next question is.... I see the Pipe for the water Closet... Is that another Pipe in the floor for a Shower? or is it already piped in for a sink? What will you be doing with that Pipe... Sorry I am sitting at a Job site And I am having the worst time seeing that Pic for some reason.
Note to self anytime you piss off an inspector be ready to pay for it! Been here for 2.5 hours for an 8:00 appoint that was 45 minutes away
Old 01-21-2011, 10:24 AM   #5
thanx for all the replies Docwhitley
ok, so the smaller pipe is for the shower drain, which i will be building later on, so it will be used.
hopefully your day gets better.
Old 01-21-2011, 10:43 AM   #6
Ok then It is possibly a simple fix... On the Vertical Pipe there is a "T" this is where your sink connects. Is there a way that you can cut out the T and have enough room to run the Pipe either in front of it or behind it? I think that the pipe you are thinking about connecting to is the vent for the Shower. Depending on how that is piped underground could cause you to have an S trap that will siphon the trap. If you can cut into the pipe with the T is your best option if not depending on if this is going o be an everyday bathroom or not would decide how I would pipe it in. If not then I would cut out a section of the Pipe Put a Y in at the bottom for the drain and then a couple feet away on the drain I would add anther y and run it up and 90 over connecting back to the vent pipe... Hope that makes sense
Old 01-21-2011, 10:50 AM   #7
thx again for the reply Docwhitley,
This is to be used as an occasional bathroom. I initial idea was also to try and run the pipe behind the existing one, but there is not enough room for that. If i run it in front, then i have to build the wall out a little bit, which I'm trying to avoid doing. the pipe that you are suggesting adding a "Y" at the bottom, it the longer pipe that runs up the wall?
Old 01-21-2011, 10:51 AM   #8
Owner
LateralConcepts's Avatar
It appears it's already stubbed out for a lav on the right side of the picture.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS,LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
LateralConcepts is offline   Reply With Quote
Old 01-21-2011, 10:53 AM   #9
i know it's already stubbed out on the right side. but, by putting the sink there, it would not be enough room on that wall, thus i am want to place the sink directly across from the existing plumbing.
DRIcore in basement, tile in bathroom windsorguy13 Flooring 5 03-09-2010 04:46 PM
Installing Bathroom in Basement Need Advice Jeffrey262 Plumbing 6 05-12-2009 07:33 AM
Basement Bathroom Insulatation/VB? mfleming Building & Construction 1 05-06-2009 05:27 PM
Plumbing Help for New Basement Bathroom morphers82 Plumbing 2 03-14-2009 01:17 AM
Venting basement bathroom fixtures ccathy247 Plumbing 1 11-01-2008 04:44 PM
