Old 01-19-2011, 12:01 AM   #1
Compact elongated toilet for a small bathroom?
I have a small bathroom for which I need a toilet, preferrably with an elongated seat. My space constraint is how far the toilet sticks out from the wall as I need space for door swing clearance. The only toilet I can find that would fit in the space is the Kohler Rialto which has a clearance depth of 25.5". However, my wife doesn't like the way it looks. Is anyone aware of any other toilets that have a similar clearance depth? Thanks.
wcb22 is offline   Reply With Quote
Old 01-19-2011, 09:51 AM   #2
Owner
LateralConcepts's Avatar
Without researching it, I'm not sure about clearance depths. I think they're all pretty comparable. What about changing the door so it swings outward instead? How 'bout a sliding door or bi-fold? Just some thoughts that might open up more options for you.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS,LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
LateralConcepts is offline   Reply With Quote
Old 01-19-2011, 10:01 AM   #3
you'll need to get a rough in book to find exact measurements. most brands have them, and you should be able to get them at a supply house, maybe online as well
the_man is offline   Reply With Quote
Old 01-19-2011, 11:07 AM   #4
Just call me Andrew
How much clearance do you have?
American Standard Cadet 3 (10" rough-in) needs 28.5" clearance (including the 2.5" between the tank and wall), which is too much for your application I assume?
I think there are toilets where the tank sits between two studs inside the wall. I assume they are expensive.
Andrew
secutanudu is offline   Reply With Quote
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
On the lower level of my condo, I have a bathroom that when the toilet flushed, the s tomgoral Plumbing 1 07-13-2010 10:59 AM
toilet installation in a new bathroom beedoo Plumbing 6 05-14-2010 10:32 AM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
