#1 |
Commode Flange Not Flush With Floor
Went to install a new high flow commode at my daughter and son-in-law's home (circa 1962 build) and when I pulled the old commode I found that the flange is about 1/2"-3/4" abve the floor. The new commode fits and the base does reach the floor, and she does not rock, but I have never seen a flange that is not flush with the floor, is this normal, is there a problem her and if so, what should i do?
#2 |
I think that is an ongoing debate here, ala Ford v. Chevy, taste's great v. less filling, or Pepsi v. Coke.
I do not know what the consensus is here, flush with the floor, or sitting on top of the floor. Obviously, as you have found, it works when it is raised. The wax ring just gets smushed a little bit more. BTW, Ford,taste's great,Pepsi. B |
| The Following User Says Thank You to Beepster For This Useful Post: | vabear (02-06-2012) |
#3 |
again, thanks, And by the way Gluten Free beer is not for all.
#4 |
The bottom of the flange should have been in full contact with the finished floor. If not the there's nothing left of the wax then it gets compressed.
Was it PVC or cast pipe? It really should have had the pipe under the floor cut, reattach the flange tight to the floor and reconnect the pipe with a hubless connector or coupling if it was PVC. |
#5 |
If the flange is solidly in place and the toilet sits solidly on the floor then the wax ring should seal it properly. The danger of a very close fit is that slight settling of the floor could result in contact followed by cracking of the toilet as the flange and toilet underside start to bear weight.
If the ring needs to compress considerably, then push the toilet down very slowly so the ring does not fissure and fracture possibly leaving part of the flange unprotected.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded. Last edited by AllanJ; 02-06-2012 at 11:58 AM. |
#6 |
Master Plumber
We will be holding a debate at the Marriott in los Vegas as to the correct installation of the closet flange all invited, please bring your own code book and liquor we may be there a while.
Experience is Knowing what to do next, Skill is knowing how to do it To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#7 |
My vote is bottom side of flange on FINISHED floor.
| Display Modes | |
| How to handle toilet flange when leveling floor | Homerepairguy | Plumbing | 11 | 12-08-2010 12:01 PM |
| Need help in flange extender for a new tile floor | eyeglass | Plumbing | 6 | 09-17-2009 09:16 PM |
| Hardwood floor questions (56K) | ukrainetz | Flooring | 1 | 08-02-2009 02:08 PM |
| Toilet flange floor advice | Hobb3s | Plumbing | 6 | 04-15-2008 10:41 AM |
| Toilet flange 1" above floor | jasoncw | Plumbing | 7 | 03-11-2008 08:05 PM |
