Old 05-07-2007, 04:56 PM   #1
Default commode air locking?
new installation, shower & commode in a barn, shower works just fine, is plumbed after the commode, when I turn on the water cutoff at the commode - if I turn it on all the way I get a sorta bang and the water quits coming in. If I barely turn it on the water will continue to run - but it sure takes a long time to fill the commode tank. Same symptoms regardless if I'm just turning it on or if I flush and wait for the refill. Any ideas? I spent one weekend constantly turning the valve on tiny bit by tiny bit ... and it worked OK on flush 1, (refilled ok without locking) then locked again immediately on flush 2.
mikim is offline   Reply With Quote
Old 05-07-2007, 05:44 PM   #2
Handyguy
Brik's Avatar
Hmmm - Not normal for sure. The problem is in one of two places. The shut-off valve or the fill valve.
To confirm the location of the problem.
Remove the supply line from the bottom of the fill valve. Direct it toward a bucket and turn on the valve. If you get flow and no bang then your problem is the fill valve inside the toilet. If its a new toilet return it for another. Alternatively you can just replace the fill valve for $10-$20.
http://www.handyguyspodcast.com
Brik is offline   Reply With Quote
Old 05-07-2007, 06:05 PM   #3
old toilet (old porcelain) new fill valve & flapper --- I'll try the bucket trick...just has me confused as to why the commode would do that and not the shower....both are off the same line in. ie: cold water in to the building to a horiz line from which is plumbed...shower on one end, water heater on other, and commode T'd off in between. It's 3/4 PVC into the building, to 3/4 cpvc, reduced at each POU to 1/2 cpvc. Hot water in/out is 1/2 cpvc. (tankless)
Old 05-07-2007, 06:21 PM   #4
Handyguy
Brik's Avatar
Could be a loose washer in the shut-off. The bucket trick will tell you if its in the shut-off or the fill valve.
More On This Topic
Hello! My name is Dwayne Carter and on behalf of expertvillage.com, I am here talking about cleaning brass instruments. What I am going to do here is flush the instrument out. From our playing you get tiny particles inside your horn that tends to stick... Read More »
I’m Lee. I have a degree in architecture and about ten years experience in construction field and today we are doing a kitchen remodel and we have to cut the hot water pipe back about four to five feet away from where it should be. So what you want... Read More »
We've all heard the frantic request from the bathroom to bring the toilet plunger before the toilet runs over. All of us will cope with a toilet malfunction at one time or another. Some repairs are best left to the experts, but many fixes are simple once... Read More »
If your flapper needs to be replaced, it’s probably the simplest thing you can do. All you’re going to do is flush the toilet, let it run out- turn off the supply line first. Once you’ve drained the tank, you’re going to simply... Read More »
Before you buy a house, it is a good idea to either inspect it yourself or hire a professional to do it for you. If you do not know what to look for, you may end up with repairs and problems you did not expect. Here are some tips on how to inspect... Read More »
Bruce Lock & Fold engineered hardwood? zel Flooring 91 09-12-2009 05:44 PM
3/4" Gravel on Sloped Driveway not locking - help? WynsWrld98 Landscaping & Lawn Care 7 10-17-2007 01:02 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
