Commercial Toilet Installation - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-09-2008, 03:37 PM   #1
Commercial toilet installation
Looking to become proficient in commercial toilet installation at the plant. I'm in maintenance and have advised management to remodel restrooms to more modern toilets and faucets etc. and want to research these skills but don't know where to find info.
THNX
downdraft
downdraft is offline   Reply With Quote
Old 12-09-2008, 09:07 PM   #2
skyman's Avatar
You need to look at Sloan's website and read some of their literature. Commercial toilets with flushometers are easy to install when after the first one. Kurby is another manufacture you can look into.
skyman is offline   Reply With Quote
Old 12-10-2008, 12:42 PM   #3
Thanks for the info
Old 12-10-2008, 04:02 PM   #4
The term "commercial" is misleading. The only required difference I have seen between commercial and residential, as far as toilets, is the seat having an open front. Using Metered flush valves (Sloan valves) and heavy duty commodes is cost efficent as far as maintenance goes. I, personally, prefer wall mount for heavy use since cleaning the floor is much easier and the dirty water isn't "mopped" all over the base.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
toilet flange extention installation handyman helper Plumbing 1 10-25-2008 02:53 PM
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 03:43 PM
Toilet installation? Raptors Plumbing 5 11-30-2007 05:12 AM
Toilet flange installation Jeekinz Plumbing 1 04-23-2007 04:15 PM
