Comercial Toilets - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-31-2009, 07:12 AM   #1
comercial toilets
Hello, I have a medium size commercial building with 3 toilets in each washroom. Each washroom has a pressure assisted toilet in the wheelchair stall which are faily new i think and a household toilet in the other stalls. The household toilets are very old and seem to flow slowly. I have changed the internal guts of these toilets with Home depot replacement parts and the line was snaked by a plumber, but now he said best thing to do is change the toilets. He is recommending $600 pressure assisted toilets but i am wondering if the code allows for me to just install a good grade commercial toilet which is about $200 only. We are in Ontario by the way.
Fordguy1956 is offline   Reply With Quote
Old 01-31-2009, 08:23 AM   #2
Rewards Points: 1,512
If you want to install "tankless" toilets your incoming water line has to provide enough volume quickly. I think the minimum pipe size is 1-1/4 inches.
Snaking a drain line does not always restore the full diameter. Problems with toilets not flushing usually have to do with a partial blockage, either in the toilet itself or in the drain pipe. I don't think you have to get a commercial toilet unless the usage is so frequent that flush handles and flappers and floats wear out quickly.
Mansfield Toilets? kcrossley2 Plumbing 9 08-23-2009 05:08 PM
All three toilets suddenly leaking clueless88 Plumbing 6 07-21-2008 06:07 AM
Tapping noise in wall after flushing upstairs toilets John VH Plumbing 2 01-21-2008 11:24 AM
wall hung toilets warnerww Plumbing 39 05-10-2007 06:35 PM
Sweaty Toilets scubamom Plumbing 4 01-12-2007 11:05 PM
