Combo Tee-wye Fittings - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-21-2013, 06:42 PM   #1
combo tee-wye fittings
Quick question....when can you use a combination Tee Wye fitting? Also, if I wanted to add a double sink in bathroom can I run a WYE to tie both drains into rather than run each sink with a separate drain?
mikem201 is offline   Reply With Quote
Old 02-21-2013, 09:32 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 996
depending on your local code??? in some places you can use a wyh on the waste arm then split the drains under the sink, some places will not allow some will.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 02-21-2013, 09:42 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 914
What is a tee wye? It's either one or the other
Old 02-21-2013, 09:47 PM   #4
Rewards Points: 14
I think he is refering to a Sanitary or San Tee fitting.
teh60 is offline   Reply With Quote
Old 02-22-2013, 08:27 AM   #5
I saw at home depot and combination Tee Wye.
Old 02-22-2013, 09:17 PM   #6
Jester there is such thing as a Ty don't give bad info if you don't know don't respond original question if your bowls of sinks are not more than 30 inches apart and you have the height you can do that
joes plumbing is offline   Reply With Quote
Old 02-22-2013, 09:31 PM   #7
Plumber
Rewards Points: 914
I know there is such a thing- but no one in my neck of the woods uses that terminology. It's either a tee, a wye, or a combo around here.
I also know how to use a little bit of punctuation when posting
Old 02-23-2013, 08:58 PM   #8
i've had to learn different termimology a few times moving from state to state. a combo is a wye+1/8th bend sometimes one piece and sometimes a wye with an 1/8 bend glued in. the the regular wye and last a sanitary tee but sometimes called a ty depending on where you live.
Old 02-23-2013, 09:46 PM   #9
when can you use these fittings?
Old 02-24-2013, 09:55 AM   #10
Master Plumber
Javiles's Avatar
Rewards Points: 996
i hear that terminology all the time, hey wye tee hey wye tee whats in your truck.
Old 02-24-2013, 12:37 PM   #11
Plumber
Rewards Points: 914
In general-
Tees in drainage can only be used in the vertical
Wyes can be used vertical & horizontal.
Old 02-24-2013, 01:00 PM   #12
Rewards Points: 2,516
In general-
Impossible to go over all scenarios but eplumber said it in general:
In the first diagram below the Wyes are actually combos(which are a wye and an 1/8 bend). SHowing the horizontal to horizontal drainage the eplumber reference. The San-T shows draining from horizontal to vertical. The fitting marked Combo below shows draining from the vertical to the horizontal
combo tee-wye fittings-proper-placemet-wye-san-t.jpg   combo tee-wye fittings-new-bitmap-image.jpg
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
TheEplumber (02-24-2013)
Air Compressor Fittings - Differences? roasted Tools 3 09-19-2012 08:15 PM
PEX Brass Fittings Turning Inside Tubing After Cinch Clamped GeeJay Plumbing 1 03-01-2011 07:06 AM
New House + PEX + Plastic Fittings = ? GaryZ Plumbing 22 01-06-2011 08:47 AM
2 gallon air compressor combo - Campbell Hausfeld or Husky? whataboutj Tools 3 11-26-2010 02:31 PM
Sharkbite brand PEX fittings at Home Depot rjniles Plumbing 1 03-16-2010 07:33 PM
