Is A Combo For A Horizontal Hard 90 Ok? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-11-2013, 11:38 PM   #1
Rewards Points: 31
Is a combo for a horizontal hard 90 ok?
horizontal to horizontal connection, and I would put a long sweep elbow and riser in the other "inlet" for a cleanout.
or is a long sweep elbow with the combo as cleanout before the hard 90?
not sure if that qualifies as "equivalent" by CA code...
706.1 Changes in direction of drainage piping shall be made by
the appropriate use of approved fittings and shall be of the angles
presented by a one-sixteenth (1/16) bend, one-eighth (1/8) bend,
or one-sixth (1/6) bend, or other approved fittings of equivalent
sweep.
Queso Bandit is offline   Reply With Quote
Old 03-12-2013, 12:26 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 348
Are you wanting to make a 90 degree turn in a horizontal line?
Use a long sweep 90 or double 45
If you need a clean out as well- then use a wye with a 45 on the wye branch to make the bend. Then add the clean out off the end of the wye.
Old 03-12-2013, 12:44 AM   #3
Rewards Points: 31
Thanks Eplumber.
Yes, I want to make a 90 deg turn in the main line.
Is a wye with a 45 the same as a combo?
Old 03-12-2013, 12:58 AM   #4
Plumber
Rewards Points: 348
Originally Posted by Queso Bandit View Post
Thanks Eplumber.
Yes it is. Although the actual dimensions will vary slightly between the 2 patterns.
The Following User Says Thank You to TheEplumber For This Useful Post:
Queso Bandit (03-12-2013)
Horizontal Studs jburchill Drywall & Plaster 1 07-06-2011 01:06 PM
Hard Duct. Garalee HVAC 4 03-08-2011 04:41 PM
Max horizontal load on vertical basement support beam supa Building & Construction 8 02-27-2011 02:51 PM
best way to secure horizontal 2 X 4s.... joetab24 General DIY Discussions 23 12-14-2010 12:56 PM
Horizontal ground loop questions with geothermal smcmurrey HVAC 1 05-14-2008 11:06 PM
