Combining Vent Pipes In The Attic. - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-31-2010, 05:47 PM   #1
Combining vent pipes in the attic.
Can I combine multiple vent pipes into a single vent pipe in the attic?
I am in the process of installing a metal roof. Currently there are 5 vent pipes exiting through the roof (1.5 to 2 inch pipes) and I would like to combine the pipes into a single large pipe that will exit through the roof. Don't want multiple pipes exiting through the new roof due to possibility of leaking and aesthetics.
In the attic, I have clear access to all of the pipes and they are evenly spaced about 5-6 feet apart. Is there a problem with running a horizontal pipes to combine them? All of the horizontal pipes will be minimum 8 feet above the highest plumbing fixture.
Thank you for your help.
Allen
a4aj is offline   Reply With Quote
Old 01-31-2010, 06:22 PM   #2
What is the purpose of each vent pipe ?
Old 01-31-2010, 07:56 PM   #3
5 vent pipes are for 2 sinks, 2 showers, 2 toilets, and 2 laundry drains. About 2 plumbing fixtures to each vent pipe.
Thanks for your help.
Allen
Old 02-01-2010, 10:05 AM   #4
Rewards Points: 3,130
I think it depends on the applicable code where you live. What you'd like to do is legal under the IRC, and in fact the log house I'm currently building is plumbed that way. It has only one roof penetration - the main stack. I don't think it would be legal under the UPC.
Old 02-01-2010, 10:12 AM   #5
Rewards Points: 150
as long as you keep a proper slope to wash each vent from the new main vent,i see no problem.use 4" to penetrate the roof and to tie all the vents together.
rudolph58 is offline   Reply With Quote
Old 02-04-2010, 11:20 AM   #6
Insert catchy title here
AppleMac*Fit's Avatar
I wanted to do this before we had our metal roof installed, but didn't. I kind of regret it. The only roof penetration on the front of our house is a plumbing one, so if we would have combined vents we could have had zero roof penetrations on the front of the house. Definitely combine them if code allows!
AppleMac*Fit is offline   Reply With Quote
Tags
plumbing , vent , vent pipes
Open Bean no Attic Bath Vent cdrusds HVAC 0 10-08-2009 03:46 PM
Trying to Vent Attic Properly stephensandlin HVAC 4 08-03-2009 11:15 AM
Can I combine vent pipes all to one in this configuration? perpetualjon Plumbing 6 04-20-2009 02:32 AM
is an attic vent required for cedar shingle roof? walenta Building & Construction 2 10-25-2007 10:31 AM
