Combining Dryer Vent With Bathroom Exhaust Fan - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-06-2010, 09:48 PM   #1
Painting Contractor
combining dryer vent with bathroom exhaust fan
My dryer vent pipe travels across my bathroom which is on the outside wall. I want to install a bathroom exhaust fan. Can I use a Y-valve and tap into the dryer vent line? It would only travel about a foot into it.
tibo613 is offline   Reply With Quote
Old 11-06-2010, 10:31 PM   #2
Chicago, IL
Michael Thomas's Avatar
Dryer vents are required to vent directly to the exterior, and cannot be interconnected with other dryer or bath vents.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
The Following User Says Thank You to Michael Thomas For This Useful Post:
tibo613 (11-06-2010)
Old 11-06-2010, 10:36 PM   #3
Rewards Points: 1,088
Unless someone invented a checkvalve, where you would need two, I doubt if you can make this happen without backflow into the house.
Plus, it's probably against code.
handy man88 is offline   Reply With Quote
Dryer vent problem carguy4sp General DIY Discussions 7 11-29-2010 09:26 AM
Vent for basement bathroom group chadmills Plumbing 1 10-29-2010 04:03 PM
Proximity of Bathroom Exhaust fan to HVAC Supply Vent? anonymouscuban Plumbing 5 04-24-2010 06:15 PM
BAD ADVICE??? You tell me! Bathroom Exhaust Fan Ventilation firefish317 Plumbing 2 04-20-2010 09:23 PM
2 bathroom exhaust fans to one outside vent pipe? CGofMP HVAC 2 03-25-2005 10:45 PM
