Cold Water Is Warm - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-26-2012, 09:37 PM   #31
Rewards Points: 6,652
Originally Posted by Malinda View Post
ok I just found another one in our shower in the 2nd bathroom as well. What does it all mean ?
Mixer valve? When you bought the home, did you have a plumber go over the system, or did the Home Inspector make any mention about a circulation system for the hot water, that looked odd to them in their report?
If you want to experiment, go to to the water heater and shut off the cold water valve to it, and then run the water for say five minutes, and see if the temp changes, or pressure changes.
Old 07-26-2012, 09:44 PM   #32
Ok I will try this in a hour or so I'm off to make dinner. Thank you
Malinda is offline   Reply With Quote
Old 07-26-2012, 10:23 PM   #33
Homerepairguy's Avatar
Rewards Points: 998
Originally Posted by ben's plumbing View Post
hey guy made a mistake wanted to thank him for his post above that one because I heard something about that when temps rise....even if i did agree with him...I would keep it to myself...look at some other post that I ask others to be careful not to offend others... Iam sorry if my mishap offended you..because it was just that a mishap...thanks...ben......
Hi Ben,
I was surprised when I saw you thanking Greg for his post that attacked me. It was so unlike you from all the posts you've made in the past, which are very knowledgeable with no offensive tones. Thank you for taking the time to clarify the mishap.
Best regards,
HRG
Homerepairguy is offline   Reply With Quote
The Following User Says Thank You to Homerepairguy For This Useful Post:
ben's plumbing (07-27-2012)
Old 07-26-2012, 10:54 PM   #34
Plumber
TheEplumber's Avatar
Rewards Points: 792
These single handle valves are controlled by a single internal cartridge that blends the H&C water as you adjust the control handle. They sometimes fail allowing hot water to pass through the valve and mix with the cold water- even in the off position. Your symptoms indicate this maybe the problem. It's easy to fix.
The Following User Says Thank You to TheEplumber For This Useful Post:
Malinda (07-27-2012)
Old 07-27-2012, 12:00 AM   #35
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Could be failed washing machine solenoids as well.
Try shutting off the washer hookups.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
Old 07-27-2012, 09:46 AM   #36
Still want to know about DM's hot cold water!
Evstarr is offline   Reply With Quote
Old 07-27-2012, 09:57 AM   #37
the Musigician
DangerMouse's Avatar
Okay, I think we're zeroing in on Malinda's problem, so.....
The first year we were out here in BFE, I worried the well might freeze up, so I put a space heater down there to keep the pipes (and pre-charge tank) from freezing. Of course, I had it thermostatted to around 45-50 degrees so it did not run constantly...... anyone see where this is going? When I lifted the absolutely snow free cover to remove the heater with the failed thermostat, it was like an oven down there!
DM
The Following 3 Users Say Thank You to DangerMouse For This Useful Post:
ben's plumbing (07-27-2012), Evstarr (07-30-2012), oh'mike (07-27-2012)
Old 07-27-2012, 09:31 PM   #38
Rewards Points: 582
my brother in law used a 75 watt light bulb over his well that is covered also very warm down there....
Last edited by ben's plumbing; 07-27-2012 at 09:31 PM. Reason: can't spell...ha ha
Old 07-30-2012, 01:32 AM   #39
I tried the washing machine thing, and it's not that. But thank you anyway..
Old 07-30-2012, 01:34 AM   #40
But it does it from all faucets including the dual control ones.
Old 07-30-2012, 01:37 AM   #41
I haven't done this yet as I couldn't figure out which one was the cold and which was the hot. I will try again tomorrow. Thanks
Old 07-30-2012, 01:39 AM   #42
If the single handle faucet is leaking hot across to the cold line then all the other faucets down stream and maybe some up stream would be warm since your cold water supply would be drawing hot water thru the leaky valve.
Old 07-30-2012, 09:06 AM   #43
Doing it myself
Alan's Avatar
When looking at the hot water heater, the cold inlet should be the one on the right, generally it's the only one with a shutoff valve.
Journeyman Plumber
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 09:47 AM
Only warm water in shower - Pfister pvstansel Plumbing 1 09-25-2011 12:42 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Warm water in cold water tank lara1234 Plumbing 7 12-18-2009 06:59 PM
