Cold Water Stopped Working In Kitchen - PLEASE HELP ME!! - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-26-2011, 02:50 PM   #16
Originally Posted by Mudman View Post
If the pipe is fully thawed and there is a leak you would know. Serious water coming out!
I did a bit of googling and clogged pipes do happen. If they are copper pipes I would assume the blockage would be at the elbow. Probably due to too much solder in the joint and mineral deposits building up there. Regardless you would drain the system and cut before the elbow. Hold a bucket up, have someone open the main a tiny bit and verify you have flow before you repair. Good luck
This could be more likely if it was my house previous to the remodel. Now the entire line leading up to the kitchen sink is PVC pipe. Does this change your thoughts at all?
annadrew is offline   Reply With Quote
Old 02-26-2011, 06:03 PM   #17
If only water lines were see-through!!
Mudman is offline   Reply With Quote
Old 02-26-2011, 07:13 PM   #18
Steeler99's Avatar
um, what do you mean all the pipes leading in are pvc? Your incoming water lines are pvc? I've never heard of that, which is why I'm asking
Steeler99 is offline   Reply With Quote
Old 02-27-2011, 08:29 AM   #19
Rewards Points: 1,214
Shut the water off to the Kitchen sink, disconnect the cold water line , put it in a bucket turn the water back on. Water Yes or No?
COLDIRON is online now   Reply With Quote
Old 02-27-2011, 09:00 AM   #20
Just call me Andrew
Rewards Points: 1,020
PVC pipe is not used for drinking water...CPVC (more tan colored than white) can be.
I am curious what the actual type of piping is that you have.
Andrew
secutanudu is offline   Reply With Quote
Old 03-07-2011, 01:24 AM   #21
Master of none
Check under the sink.
I have had 2 cases where a water line got clogged due to an obstruction. both cases a valve washer coming apart. BUT these were in old-old plumbing and there was some water but not the flow that we want!
Because nothing else makes sense, I suggest you try the following. Disconnect the cold feeder line to the kitchen faucet, (after shutting off the valve of course), then slowly turn on the valve. If you get water coming out, then the blockage is in the faucet.
Now another thing occurs to me. Sometimes the shutoff for an outside tap is in the undersink cabinet. Is it possible that someone shut off the cold water valve for the sink instead of the one for the outside tap?
handy andy is offline   Reply With Quote
Old 03-07-2011, 09:34 AM   #22
Thanks - /Water Works - ??
Well, just to update folks.
I called my plumber and left a message to get his idea also as he was the one who just recently put the plumbing in.
His ideas were similar to yours but it turns out that I didn't need his help with it either as .....
...while I was waiting for him to reply to me I was in the kitchen cooking dinner when I heard a sort of soft whistling noise or a slow drawn out whooshing noise.
I didn't know what it was as it was a background noise at the time not very loud. But when I looked around to see if it came the kitchen or maybe from outside I caught my wife looking also.
Then it hit me that it sounded a little bit like air or water going through a pipe.
I went outside and turned on the hose. Water came flowing out like normal. I went back to the kitchen sink and tried it and the water now worked like a charm.
Thanks for your ideas.
It worked out all by itself.
Old 01-10-2015, 01:07 PM   #23
Rewards Points: 4
I lost my first account info and don't have that email anymore so I had to make up a new account. I'll just add onto this thread since my problem is same except for the outside bibb is working fine. There was an icicle hanging from it, but when I turned it on water came out as usual. Temperatures here have been below zero this week and I guess I just didn't have the cold water flow on quite enough to prevent a freeze. The only water supply I'm having trouble with is the cold supply for the kitchen sink which is directly behind the outside bibb. I've been heating up every area that's ever frozen before and had a salamander going in the crawl for an hour (yeah I know I know). The only thing I haven't tried is putting the salamander outside on the bibb. Any ideas?
xcodyx is offline   Reply With Quote
Old 01-11-2015, 10:36 AM   #24
Rewards Points: 4
Well I gave up and called a plumber. There was a spot in the crawl where the pipe was still pvc and not pex. That spot was where the ice blockage was.
Old 01-11-2015, 02:19 PM   #25
Rewards Points: 1,700
And plumbers ***** at me when I make them remove water from outside walls. GEEZ.
Tags
cold water , help me please , new plumbing , new sink , stopped working
low domestic hot water flow with tankless coil mike42 HVAC 28 11-24-2011 09:35 AM
No hot water in kitchen and dishwasher is not filling water lol Plumbing 3 09-07-2010 12:47 PM
Low/No Hot Water Pressure after changing Elements Onehipcat Plumbing 18 08-05-2010 10:16 AM
Cold water not working. Is there an easy fix? Shpigford Plumbing 4 12-16-2008 01:07 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
