Old 08-03-2012, 01:17 AM   #1
Cold water smells
OK, so here is the story. We have a well, and our pressure tank was low on air. So we started to fill it, unfortunatly by doing this put to much pressure on the old hot water heater and blew a hole in it. So now we have no hot water but pressure tank works great. BUT now when we turn on the cold water it smells like rotten eggs. Please keep in mind, atm we dont have hot water and our water has never smelld before also the well has be tested and does not contain sulfur.
austin68 is offline   Reply With Quote
Old 08-03-2012, 09:08 AM   #2
Civil Engineer
Cold water smells
You said the water "has to be tested" and it does not contain sulfur. Do you mean that you had the water tested, and it did not contain sulfur? Rotten egg smell is often caused by sulfur in the water, which is not going to get into the water from a broken hot water heater, but must be getting into the water from the well. I suggest you take a sample of water to a qualified laboratory and have them test it to see exactly what it is that is causing the odor. Then you can develop a plan to handle the problem.
Old 08-03-2012, 10:24 AM   #3
Doing it myself
Alan's Avatar
Cold water smells
The only other thing I can think of is that you may have had a hole in the bladder of the pressure tank, and that was why it was low on air. When you charged it back up you blew the stagnant water from the top of the bladder back into the system.
No guarantees, but it's a guess.
Journeyman Plumber
Old 08-03-2012, 11:44 AM   #4
Cold water smells
Im sorry, the water was tested about a month ago for other reasons. It does not contain sulfur. I have been running the water for a few hours, and the smell will eventually go away. But after it sits for a bit it comes back.
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
No cold water!! Hot coming out in the cold faucet! HELP Marilynjp Plumbing 6 01-04-2010 07:40 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
