Cold Water In Shower In New Apartment - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-19-2012, 11:07 PM   #1
cold water in shower in new apartment
I cannot get really cold water in the shower of my new apartment, and I assume the is because it has a mixer valve, different fron my old apartment. Is there any way to make the water colder,as in my previous apartment?
Lynny is offline   Reply With Quote
Old 05-20-2012, 05:05 AM   #2
Rewards Points: 14,306
Well that's a first, someone wanting a cold shower.
Is the cold water also to warm at the other faucets in the house?
If the water heater is in your apartment check to see if the temp. set to high.
The anti scald valve inside the shower valve can sometimes be adjusted or taken apart and cleaned if it's sticking.
ben's plumbing (05-20-2012)
Kohler single handle shower - no cold water molomoore Plumbing 0 01-04-2012 03:00 PM
Hot Water in Cold Water Lines ??? Superbuuck Plumbing 14 08-29-2011 12:21 PM
In AZ, hot water from the cold water pipes maynard7 Plumbing 12 08-06-2011 01:43 PM
Low cold water pressure in shower peezee Plumbing 2 05-07-2011 04:30 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
