Old 06-11-2008, 07:25 PM   #1
cold water runs hot
When I turn on my cold water taps in bathroom sink or kitchen, the water runs hot for a very long time, finally cooling to lukewarm. I never get truly cold water. I can get cold water first thing in the morning, or late in the evening. What is a likely explanation/fix for this? This may be ridiculous, but is it possible that the Phoenix heat plays any part in this (108-115 in the summer)?
We live in a single story home, no basement, with PVC plumbing throughout.
phxhouser is offline   Reply With Quote
Old 06-11-2008, 08:11 PM   #2
Electrician
cold water runs hot
You have a cross connection somewhere....
do you have one of these installed?
chris75 is offline   Reply With Quote
Old 06-11-2008, 09:27 PM   #3
Journeyman Plumber
Ron The Plumber's Avatar
cold water runs hot
Check the dip tube in the water heater, it could be the problem.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 06-11-2008, 10:00 PM   #4
Licensed Master Plumber
mstplumber's Avatar
cold water runs hot
How old is your home?
Do you have any type of circulation pump installed?
Has this just started?
Mstplumber
Check out my goofy video for my new
mstplumber is offline   Reply With Quote
Old 06-11-2008, 10:03 PM   #5
Journeyman Plumber
cold water runs hot
My Bad, you said cold water.
Ok if you have Moen faucets in the house, it could be one of the cartridges gone bad, yea sounds odd, but I have encountered this a few times.
Hot Water in Cold Water Lines ??? Superbuuck Plumbing 14 08-29-2011 01:21 PM
advice on cold water pipe in basement garage area cambie Plumbing 6 10-15-2008 02:29 PM
PVC Pipes Pop And Click When Water Runs jasonsullivan Plumbing 3 01-16-2008 03:41 PM
can't shut off cold water from main disconnect DanBress Plumbing 3 01-06-2008 07:20 PM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
