Old 07-28-2010, 07:31 AM   #1
cold water is running hot
I live in a mobile home and in one end of the house I have noticed that the cold water is luke warm and does not run cold. Last night the outside water hose did the same thing. My electric bills are outrageous! What is it; the water heater??
HollyMacIntyre is offline   Reply With Quote
Old 07-28-2010, 08:04 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
There are different possibilities why this may be happening.
One is that if you are on public water and the pressure is too high, and a Pressure Reducing Valve has been installed on your main water supply line without an expansion tank near the water heater to control the hot water expansion back into the cold water lines.
Solution: Add small expansion tank.
Another is that there may be a faucet that is faulty somewhere in your home for some reason, allowing hot water to expand back into the cold side through the faucet body.
Solution: Go through the process of eleinination and repair or replace that faucet.
Others here may have additional suggestions.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
low domestic hot water flow with tankless coil mike42 HVAC 28 11-24-2011 09:35 AM
Hot water starts hot but gets cold quickly. CenterShock HVAC 31 12-26-2009 06:06 AM
Water Heater - Water reversed, hot is cold, cold is hot acaciaavenue Plumbing 5 12-09-2009 12:00 PM
Hot water keeps running Ed36 Plumbing 4 05-14-2009 01:39 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
