Cold Water Running Amok In Hot Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-25-2011, 01:31 AM   #1
Cold water running Amok in Hot pipes
I am currently pulling my guest house off grid. I want to run hot water from a solar thermosiphon system but not yet. In the interim, I want to run cold water only through our home.
I pulled the electric hot water heater off the system left the feed line to it simply "cut" hanging out in space. When I turn on the water feed to the house, cold water spills out of this line. Is this normal? Should I simply cap this line or is there a bigger problem? My feeling is that there is a a bad seal in a faucet or toilet in the house that is allowing cold water to run to the hot side, but maybe it's something simpler.
Any comments?
genproj is offline   Reply With Quote
Old 04-25-2011, 07:27 AM   #2
A water heater always has a cold feed and a hot out line. Obviously, water will come out of the cold line if the water is turned on. Any faucet that has the hot valve on, will allow cold water into the hot lines when the cold side is turned on. Sometimes there is a recirculation loop to allow hot water to flow faster. If there is one, that should be turned off.
Old 04-25-2011, 07:56 AM   #3
Plumb or Die!
Why not reconnect the tank, and just shut off the breaker if you don't want hot water? Or better yet, leave the tank in operation untill you do your solar siphon whatchamicallit?
plumber666 is offline   Reply With Quote
Tags
cold water , cold water line , plumbing
Sound of Water Running in Pipes rpishotti Plumbing 4 12-06-2010 01:09 AM
cold water is running hot HollyMacIntyre Plumbing 1 07-28-2010 08:04 AM
Hot and cold water pipes under basement floor? alondis Plumbing 13 06-28-2010 07:56 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
