Cold Water Reroute Outside With Pex Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-22-2011, 02:15 PM   #1
cold water reroute outside with pex pipe
I have an older home that had a cold water leak under the slab. The plumbers ran 3/4 Pex pipe through the yard to the other end of house and drilled into the cinderblocks to rehook water to kitchen. They also put a water faucet outside the wall. Where it goes into the house is all exposed, Have I been duped or is this how a rerouting would go.
Thank You
staylor7737 is offline   Reply With Quote
Old 07-22-2011, 02:27 PM   #2
Homerepairguy's Avatar
Rewards Points: 998
You have been duped. Pex must be shielded from direct or indirect sunlight as it deteriorates when exposed to UV. So where it comes up from the ground and goes into the house, it must be completely shielded from any sunlight.
That aside, if you live in an area that can freeze water, you are also in trouble.
HRG
Homerepairguy is offline   Reply With Quote
The Following User Says Thank You to Homerepairguy For This Useful Post:
staylor7737 (07-22-2011)
Old 07-22-2011, 02:35 PM   #3
I knew it didnt seem right. What should have been used to repair the line? I do live in a southern state , but still freezes. Flat roof , just crawl space so couldnt put it in attic and its replacing a galvanized pipe. thank you
Old 07-22-2011, 04:56 PM   #4
Rewards Points: 998
Maybe pictures will help others get an idea of your particular situation.
I live in an area that never freezes but do know that in areas that can freeze, underground pipes must be below the frost line, pipes must come up from the ground in a heated area that won't freeze. Pex must be shielded from direct or indirect sunlight.
HRG
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Do I need a ground rod to replace copper water pipe mfkcbk Electrical 10 11-11-2010 04:03 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Hot water starts hot but gets cold quickly. CenterShock HVAC 31 12-26-2009 05:06 AM
Sump pump discharge pipe: the standing water trap! Deck Plumbing 7 05-19-2009 11:53 PM
