Old 12-27-2007, 05:35 AM   #1
Unhappy
cold water radiator
Does anyone have any idea why my radiator is cold ? I have bled it and there is no air in it, all of the pipes around it are hot and the radiator valve is set to full on.
thanks in advance, "Freezing in rugby."
evertheoptimist is offline   Reply With Quote
Old 12-27-2007, 01:08 PM   #2
Custom Cabinet Maker
cold water radiator
is it hot on the system side of the radiator valve? If so the valve may have gone bad. There is still the possibility of air, also check if you have zone valves that one of them has not gone bad or a broken wire.Usually there is a manual over ride with zone valves, if you can find the correct one try to do that and see what happens
skymaster is offline   Reply With Quote
Hot Water System -- Cold Radiator formarley HVAC 4 03-04-2008 08:09 AM
Water from cold water faucet goes from cool to hot to cool tima2381 Plumbing 6 05-22-2007 09:02 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
hot water effecting cold water pressure hp1964 Plumbing 1 06-23-2005 05:51 PM
