Cold Water Pressure Low In New Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-16-2011, 10:15 AM   #1
cold water pressure low in new faucet
Plumber installed new faucet, the cold water worked fine for 4 days then pressure dropped to less than 50% Kholer sent new valve, no difference. They had us switch the cold line to the hot to see if it would work--it did. Tried hot water tubing on cold but same result low pressure. Kholer says not their problem. Ideas?
tndale is offline   Reply With Quote
Old 03-16-2011, 02:15 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Sounds like loose floating debris in the cold side of the faucet.
Turn the water off, dismantle the faucet and cover it with a towel.
Turn the water back on very briefly to flush the debris out of the faucet body. That should clear it. Been there. Done that.
Sometimes, you have to take a small Phillips head screwdriver or an icepick to break up the little hungup piece of debris so that it will flush out.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Low/No Hot Water Pressure after changing Elements Onehipcat Plumbing 18 08-05-2010 09:16 AM
Low Water Pressure Only on Kitchen Faucet Chsmadden Plumbing 4 03-21-2010 09:01 PM
Intermittent Low Water Pressure Fox Plumbing 4 03-02-2010 06:04 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
